#43 | |
![]() Drives: 22 Camaro 2SS A10 Join Date: Jul 2010
Don't tell me you got rid of the Z!? That thing would be fun after an LS swap.....
2022 Camaro 2SS A10
2007 Trailblazer SS |
#44 |
![]() ![]() Drives: 2020 Camaro 2SS Join Date: Nov 2022
Yes, it was traded in on the 2020. The ride was too rough, and I was tired of dumping money into it. The guy who bought it from auction also sold it because of the rough ride, LOL.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
#45 |
What do you mean? Like the suspension components are shot? Old tires?
2022 Camaro 2SS A10
#46 |
It was lowered.
#47 |
By request, here are some more pics of my stereo install, with pics of the power and ground connections.
In this first pic, the 1/0 gauge red cable to the battery is the factory power cable. The 4 gauge red cable at the same connection is the power cable for the amp. The other wires will be explained in subsequent pics. The black wire attached to the ground wire on the battery is the ground wire for the battery charger.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal Last edited by DamonZ28; 02-19-2023 at 08:22 PM. |
#48 |
In this pic of the top of the battery, the 16 gauge wire with the blue connector is the power wire for the line output converter. The black wire (with the fuse at the left side of the pic) is the power wire for the battery charger. For reference, the connector that says 350A is where the main power cable attaches to the battery.
#49 |
The 16 (18?) gauge wire in this pic, with the fuse toward the middle, is the power wire for the line output converter. The clear spots in the wire are heat-shrink solder connections (the sleeve is clear, the wire is not bare/open).
#50 |
Here is a pic of the wiring going toward the front of the car. The 4 gauge cable for the amp is running along the 1/0 gauge power cable for the car. The amp fuse is circled in black. The amp power on wire is circled in blue, and comes from the line output converter. The line output converter and the amp are grounded to the bolt circled in red.
#51 |
Here's the battery with the cable protector installed. The previous owner must have broken the cover. I should look for a new one.
#52 |
Here are a couple of pics of the sub & amp, after cleaning up some of the wiring. I need to figure out a better option for keeping the sub in place. WOT acceleration has caused it to move around in the trunk, even with velcro strips on the bottom of the box.
#53 |
Sir, you are a gentleman and a scholar!
2022 Camaro 2SS A10
#54 |
I discovered that the subwoofer rolled around in the trunk after some experimenting with Launch Control and WOT acceleration. I came up with this solution to prevent further rolling around. Zip ties and saddle bases (the bases are screwed down). Might need to add a 3rd zip tie but we'll see how it goes.
#55 |
Installed a gloss black eBay fuel door. I like it.
#56 |
Well, the zip ties holding the subwoofer enclosure failed. They didn't even last a week. They both snapped where I have the holders attached to the enclosure. Luckily the sub didn't move. Next I'm going to try bungee straps to see if they'll work. I'll be attaching them in the same manner as the zip ties, more or less, except with ratchet straps tie downs attached to the top of the enclosure.
