Old 11-03-2022, 10:01 PM   #43
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Good luck, hopefully there’s no damage beyond the already repaired wiring and the blown CGM fuse. That would be ideal….
Old 11-03-2022, 10:09 PM   #44
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Originally Posted by stormtrooperSS1le View Post
Here is what I pulled from hptuner. Assuming these are redundant based on one major issue being the wiring. I can clear these but they come back. I will check fuses tonight in trunk and engine.
I know when my harness was damaged, the same thing happened with the codes coming back after clearing. We found that a couple of my sensors were damaged INSIDE the connector. The damage was basically UNSEEN but it was there. On this PARTICULAR occasion my AC belt had broke and it wrapped itself around the harness around the front engine cover. Obviously the ECU was not getting the correct readings due to the circuit being OPEN.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 11-04-2022, 06:20 AM   #45
stormtrooperSS1le
Drives: 2017 camaro ss 1le
What does the cgm fuse even do been having some trouble finding?
stormtrooperSS1le is offline   Reply With Quote
Old 11-04-2022, 08:41 AM   #46
Chutzpah
Chutzpah's Avatar
Central Gateway Module - From Google Search - https://www.einfochips.com/blog/what...omotive-world/
Old 11-04-2022, 09:03 AM   #47
stormtrooperSS1le
Ah so it is half the brains it seems like. Hopefully that restores my car.
Old 11-05-2022, 10:57 AM   #48
stormtrooperSS1le
Update and solved.
CGM fuse blew out and all my modules weren’t communicating. Fixed the wiring and replaced the fuse now all is good fires right up.
Will drive it after I top off some coolant.
Old 11-05-2022, 11:41 AM   #49
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
Update and solved.
Awesome...! Happy Ending and saved your self a LOT of cash! Nice
jamala00 is offline   Reply With Quote
Old 11-05-2022, 02:54 PM   #50
Chutzpah
Chutzpah's Avatar
Congrats, it’s nice when things work out!
Old 11-05-2022, 05:22 PM   #51
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
Nice work! Congrats!
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 11-05-2022, 07:04 PM   #52
stormtrooperSS1le
Thanks for all the helps fellas!! Hopefully the issues stay away now!
