#43 |
![]() ![]() Drives: 2015 Camaro ZL1 Join Date: Oct 2020
We use a Fragola -6 bulkhead fitting.
Pulling the tank to install the bulkhead is still a 1/4 of the work it is to install an in-tank set up like a Fore twin or triple. |
#44 | |
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#45 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Hey Mike, Can you elaborate on why the in-tank pump is 3X the work for the AUX? Assuming you need to either drop the tank, or cut an access panel for either?
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#46 |
Moderator
Fore setup is a return style system and designed for big power. So you’re adding pump controller, bigger fuel line, return line, regulator, Hobbs switch to activate pumps 2 & 3, etc. And they don’t give you brackets, heat shielding, etc. It was a healthy amount of work for the new Fore system to go in. If a shop bangs that out in a day it will not be a nice install lol…
#47 | |
The DSX kits are pretty plug and play other than drilling the tank. Much quicker install. |
#48 | |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
How much whp are they capable of on full E Mike? Thanks!
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror ![]() |
#49 | |
#50 | |
Moderator
#51 |
Old badass
Thanks Josh great insight. Mike I was referring to how much would the DSX supply?
#52 |
