09-17-2023, 08:45 AM | #43 |
Drives: 2024 ZL1 M6, 1969 Cessna Skylane Join Date: Jun 2018
In my experience batteries last exactly one month past the warranty expiration.
09-17-2023, 12:57 PM | #44 | |
09-18-2023, 12:15 PM | #45 | |
There's some voodoo with AGM's. I've had new ones with current manufacture dates test anywhere between 12.7 to 12.98 volts fully charged. Supposedly some can hit over 13 volts. I haven't hit that yet. Not sure if the higher voltage translates to longer life. |
09-18-2023, 03:41 PM | #46 |
Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
May 2016 build, purchased Labor Day 2016, daily driver still on original battery. I had a hot start/slow crank issue last week that required a jump start. I've had hot start/slow crank issues on occasion, but this was the first time it failed to start. Checked the resting voltage the next day - 12.2V. Got 7 years out of it. Replacement battery should be delivered this Friday.
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
09-27-2023, 12:50 AM | #47 |
Drives: 2016 Camaro 2SS A8 Join Date: Oct 2016
3 years or so is the most I've gotten out of mine but the Southern heat is pretty hard on them. Same with all the vehicles I've owned.
09-27-2023, 08:55 PM | #48 |
I leave my antigravity on trickle charge 24/7
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
11-08-2023, 02:56 PM | #49 |
Battery Life
I have a 2020 Camaro 2SS build date:Nov.2019 with only 10,760 miles on it and I still don't need to change my stock battery. I use a smart charger once a month and if the charge "zeroes" out, the battery is good. When it finally gets too tired to show a full charge then that's when I will get a new H6 AGM.
11-08-2023, 05:31 PM | #50 |
Drives: 2023 1SS 6 speed Join Date: Aug 2023
Two years. I’m changing it out before it leaves me stranded.
11-12-2023, 09:54 PM | #51 |
Drives: 2SS, CT-R, LC500 Join Date: Jan 2018
2016 SS (built late 2015, I think) original battery is still going. Only drive 3-4000 miles a year. Short drives only, 5 miles or less, one way. Car is usually outside the garage in hot & sunny Florida except 1 week a month.
Last year, it seemed like it was going to go dead, but I started hooking it up to a battery tender with "desulfator". Now, its as strong as ever. I used to have hot start issues, not any more, after using the battery tender. |
11-13-2023, 05:35 AM | #52 |
Thank you Al Oppenheiser!
It's a trunk mounted AGM, so 7-10 years should be expected minimum. Our cars have overly-conservative thermal protection charging logic that will tend to result in under-charging, so folks like myself with garage queens may get fooled into premature replacement. Seen it happen to daily drivers too. Throw a tender on the battery for a day or so every quarter to avoid this. If you keep it healthy, it may last 20 years.
