#43 | |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
#44 |
![]() Drives: 2018 HYPER METALLIC BLUE ZL1 Join Date: Mar 2021
2018 metallic blue here 2nd owner with 31k miles and haven’t had one problem at all. From these pages seems like I’m a lucky one.
#45 |
![]() ![]() Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
2018 zl1... just hit 6900 miles.
#46 |
![]() Drives: '18 ZL1 1LE Join Date: May 2020
2018 ZLE, bought brand new, getting ready to hit 41,000 miles. Daily driven, modified with JRE125 flex fuel package at around 12,000 miles. No issues thus far. Still on original battery, brakes, and oil pump.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
#47 |
Dyno Show Queen LOL
2017 40k plus 1044 rwhp oem pump reused w no problems... same oil pressure since cam change about 3 1/2 years ago. reused oil pump since car had 7 miles this was before all the hype this oil pump issue must of been stared by a covid scaredy cat
#48 | |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
#49 |
ZL1 Driver
That is great to hear, especially about the oil pump.
#50 |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
I have a 2017 ZL1 from the very first production run of 6th gen ZL1s in October of 2016. My car has a little over 15K miles on it. Other than replacement of the OEM paper air intake filter with a high flow Green filter and removal of the rain/snow blocker, my car is all stock.
The only problem in nearly six years of ownership has been a bad bearing in the supercharger idler pulley. It was replaced under warranty. My ZL1 still has the original battery which tested fine at my last oil change in May.
#51 |
![]() Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC Join Date: Feb 2018
2018 9000 miles replaced my oil pump when I did heads and cam with the newer flavor of the GM pump. Just had to rebuild the transmission.. :( put a 3000 Circle D stall in it to help with them 60 foots!
2019 COPO #32
350 SC 8.25 167MPH 2018 ZL1-NFG-A10 388CI L8T 9.32 147MPH |
#52 |
![]() Drives: 2017 ZL1 Coupe White A10 Join Date: Feb 2017
2017 Zl1 A10. 37100 miles. Check engine light at 4800 miles. Code p050d bad fuel injector. GM replaced all injectors on bank. Original oil pump. Solerperformance throttle body, otherwise all stock.
#53 |
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
Seemed to go Ok. I only stopped by the dealership once to check it out while they were doing the install. Was only without the car for 4 days.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#54 |
ZL1 Driver
#55 |
ZL1 Driver
I was thinking about a throttle body. Have you noticed a performance upgrade?
#56 |
Rockcrusher
Drives: 2017 SS 1LE Join Date: May 2009
Original owner 2017 1LE SS. 12,700 miles. No problems whatsoever.
