Old 08-29-2022, 10:18 AM   #43
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Which Whipple do you have?
Mine mounts under the hatch floor so I don't lose any trunk space [I never put anything back there anyway, but...]
Kong ported 2.9 (for now lol).
This tank was stealth but obviously not anymore.
Old 08-29-2022, 10:33 AM   #44
JSH
JSH's Avatar
Drives: '20 ZLE
You and I have pretty much the same builds except for my ported 2.65. We'll dyno it this week after the Big Gulp arrives. Actually, I'd like to dyno it now with the 4" CAI and then with Big Gulp to measure any improvement.
The OEM Gen 6 Lt4 short block is forged, so I wonder if yours is custom built?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 08-29-2022, 05:55 PM   #45
Joshinator99
Moderator
Yes, forged pistons with LT4-level compression and forged rods on factory LT1 crank. Mast Motorsports Black Label LT1 heads and CamMotion custom ground cam. Johnson 2110R lifters, extreme duty intake valves and inconel exhaust valves.
Old 08-29-2022, 06:47 PM   #46
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
You will need to tune for the 5" intake before making a dyno pull.
Old 08-29-2022, 07:29 PM   #47
JSH
JSH's Avatar
Drives: '20 ZLE
I am thinking of tuning for the current 4" setup, dynoing, then installing Big Gulp and repeating. Are you saying, why bother tuning for the 4" dyno?
2020 ZL1LE A10.
Old 08-29-2022, 07:54 PM   #48
Joshinator99
Moderator
He’s saying the 5” tube will drastically alter your MAF scale. It’s a good amount of tuning to make the BG work. You can’t just dyno on the 4” tube, slap on the 5” one and make a pull. And that we’re slightly off topic…
Old 08-29-2022, 08:55 PM   #49
JSH
JSH's Avatar
Drives: '20 ZLE
... we’re slightly off topic…
LOL, every thread at this site eventually goes off topic. In your case, your sig has a bunch of mods, and the tank is a mod, so, we're still on the topic of mods.
2020 ZL1LE A10.
Old 08-30-2022, 01:50 AM   #50
Joshinator99
Moderator
So just as an update I emailed Weapon X my list of design & quality issues with their tank setup, and how it cost me nearly double what it should have to install this kit. Their response was (boiled dowm): “Gee, sorry, we never realized any of that!”… Awesome.
Old 08-30-2022, 08:13 AM   #51
JSH
JSH's Avatar
Drives: '20 ZLE
I just bought a Billet direct inlet coolant manifold and Big Gulp from them and assumed they're just a broker or middleman, if you will, who probably doesn't investigate each part they sell.
2020 ZL1LE A10.
Old 08-30-2022, 09:10 AM   #52
Joshinator99
Moderator
They actually make some of that stuff themselves (like your coolant manifold). The ice tank was their design & build.
Old 09-13-2022, 01:48 PM   #53
asthmamax11
asthmamax11's Avatar
What engineer designed this without testing it oit first ?
Tank being lower than the IC is unforgivable
I saw a prototype of an ice tank that goes on top of radiator. A shop designed it.
Also had tubing that prevented ice chips from getting stuck in the tubing
Late Model Performance
https://youtu.be/ XZYuFUOhdGA
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 09-23-2022, 11:58 AM   #54
JSH
JSH's Avatar
Drives: '20 ZLE
This morning with IAT temp at 70F, MAT was 102 at 7000 with no ice (?)
2020 ZL1LE A10.
Old 09-23-2022, 06:51 PM   #55
asthmamax11
Dumb question:
Say you're using this and temperatures freeze over night.
What if the water freezes and cracks the piping, etc ?
Or will you just empty it out before end of fall
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 09-23-2022, 07:19 PM   #56
Joshinator99
Moderator
Originally Posted by asthmamax11 View Post
Dumb question:
Car is not driven in cold weather. My wife would say I don’t actually drive it at all. It sits in a heated & air conditioned garage.
