11-03-2022, 12:20 PM | #43 |
Drives: 2016 Camaro SS Join Date: Apr 2019
Thanks....
11-03-2022, 06:30 PM | #44 | |
Drives: '23 2SS RSblue 6MT, sold '19 ND2 Join Date: Dec 2021
Well I spent alot of time on BITOG, the distillates is GTL base oil (made from natural gas). Both have similar PAO (5-10%). So x3 might have a bit less GTL and some group iii to thicken up the HTHS. A higher HTHS requires a thicker base oil. Based on my non-scientific analysis, the formulas look very similar. Both should perform well.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 |
11-04-2022, 07:24 AM | #45 | |
Electrical Engineer
Is there a BITOG post comparing these I can reference?
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
11-04-2022, 09:31 AM | #46 | |
Drives: 2022 2SS 1LE 6 MT Join Date: Aug 2022
https://bobistheoilguy.com/forums/th...fusion.360760/ There is also a post about Supercar: https://bobistheoilguy.com/forums/th...er-car.357422/
2022 Camaro 2SS 1LE
Rapid Blue || 6MT |
11-04-2022, 12:13 PM | #47 | |
DexosR is a money making move. If dexos2 was previously sufficient, what changed? The engine surely didnt. With the Camaro going away, this is going to be the "corvette" oil for 12-15 bucks a quart. What other oil producer besides mobil 1 is going to pay for certification with GM for "super cars"? With dexos2, it at least included a wider range of diesel engines and still readily available oils were slim pickings. Mobil is in bed with GM. The whole reason why they shifted to Dexos2 for factory fill is because GM is on the hook for the federal emissions warranty 8yr/80k and before they advised to use Mobil 1 15w50 full synthetic on the track. If look at the specs of this oil, it is much higher in in zinc/phosphorus which supposedly poisons the cat converter. That is why they instruct you to change back to 5w30 after track. With the ESP oil, they don't have to worry about that because its "mid SAPS" and has less of zinc/phosphorus which will get you through the warranty period. This oil is also thicker with higher HTHS = high RPM protection. Incidentally, this is also better for diesel particulate filters or gasoline particulate filters. All this to say: its not bad oil, and I do like Mobil 1 in general. But I'm not falling for this BS just because my vehicles a '23. Especially when they concede (even in the '23 manual) that Dexos1 5w30 will be sufficient for street use. Any Dexos2 0w40 oil will be much more stout than Dexos1 5w30. M1 ESP 0w40 X3 is available for 6 bucks a quart and looks to be an excellent product.
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 Last edited by haggler; 11-04-2022 at 01:03 PM. |
11-09-2022, 01:14 PM | #48 | |
Electrical Engineer
I'm still studying the catch can debates. Seems unnecessary but also seems to have benefits. https://bobistheoilguy.com/forums/th...5#post-6269684 thread #88 details my concern with the new Honda turbo engines but this is the first i've seen a solution by changing oil and fuel. Things are easier with my 210k mi Honda and 50k mi Toyota just wanting 0W-20 or 0W-16, respectively, of any type of Mobil 1 Full Syn I want to use, though the rabbit hole of oil additives and variants may change result in a more specific selection, and the higher mileage model may move to 0W-30 M1 ESP. Neither are turbo and neither seem to have issues with gas in the oil.
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 Last edited by keep_hope_alive; 11-09-2022 at 01:44 PM. |
11-11-2022, 11:32 AM | #49 |
Yes, the honda issue is largely summed up by this post and also the persons driving style. Efficiency is at odds with warming up the engine in something like a CRV with a tiny 1.5t, these folks are not exactly opening up the engine. Toyota's solution with dual injection is the best solution, but I think only GDI can work if you maintain a conservative oil change interval factoring in your driving environment (city/hwy), ambient temps, and driving style. I won't use anything not Dexos1 spec'd.
For the SS, I don't anticipate this being an issue. For one my car is manual, so I tend to hold higher gears rather than upshift quickly, especially when warming up the vehicle. As far as the catch can, I don't think that is as big as an issue as some people make it. Yeah I don't expect the intake valves to be as clean as a port injected vehicle, but this largely hasnt been a widespread issue since maybe mid to late 2000s on various euro GDI engines (VW/Audi/BMW). Its an over blown issue especially when using high quality gasonline (top tier) and oil (mid SAPS). I personally wouldn't add another failure point on a 50k car under warranty, but thats just me. Some people supercharge the car with 500 miles.
11-12-2022, 09:57 AM | #50 |
Thank you Al Oppenheiser!
Also, if you send oil samples off to Blackstone labs you can get direct feedback on any concerns of fuel dilution (or any other issues) arising from your driving style, oil and/or filter choice, and choice of oil change interval...
11-13-2022, 12:36 PM | #51 | |
Drives: 2018 1SS 1LE Join Date: Sep 2011
11-13-2022, 05:50 PM | #52 | |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
12-13-2022, 11:42 AM | #53 |
People still squawking about ESPx3 not being OK. Still no data to back up the claims. I don't get it.
2022 Camaro 2SS 1LE
Rapid Blue || 6MT |
12-22-2022, 11:12 AM | #54 |
Had $35 in Rewards to use...might as well get 5 more quarts plus a filter for $7.39. Still need to return all my filters.
2022 Camaro 2SS 1LE
Rapid Blue || 6MT |
12-31-2022, 04:39 PM | #55 |
Drives: 2018 ZLE Join Date: Feb 2018
Not according to mobil 1, give them a call.
12-31-2022, 05:02 PM | #56 |
America FVCK Yeah!
Drives: 2021 ZL1 1LE A10 Join Date: Mar 2013
My guess is that GM asked Mobil1 to help reformulate the oil with more zinc and less phosphorus to protect the cats. I won’t own mine past warranty which is 2025 and 48K miles so I’m not buying SUPERCAR until the price is the same as ESPx3 Dexos2.
1997 Z28 Anniversary Edition SOLD
2004 GTO ORDER CANCELLED 2004 CTS-V SOLD 2005 CTS-V SOLD 2006 300C SRT-8 SOLD 2006 300C SRT-8 SOLD 2010 CTS-V SOLD 2012 CTS-V coupe SOLD 2013 ZL1 vert SOLD 2016 Callaway Z06 SOLD 2019 Z06 SOLD "I lived my life by one motto.......mottos are for losers" cvp33 |
