#43 |
700 x .8 = 560 actual in Lakewood (8000 ft. DA, 5800 ft. elev.) using std. 20% correction factor
Again, you can make 700 corrected with just valve train/heads, headers, and tune on 91/93 oct. and don't touch your blower or throttle body. Might have to put a tad larger lower on it.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#44 | |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
#45 |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
The corrected (SAE) numbers will still be 25-40whp less than what the car would make at sea level because the supercharger will make about 2.5 lbs less of boost due to the altitude.
#46 | |
![]() Drives: 2019 ZL1 Join Date: Oct 2020
#47 |
Not sure i understand your question. I would maybe throw a jms booster in there as it's cheap and will help with the lowside pressure. Next would be high side pressure which your addressing with the cam. Car should run good with a setup like yours, personally I'd upgrade the valvetrain while you're getting the cam done. Ethanol will help the engine run cooler and raise your octane once you're ready to go that route. I'd also install the flex fuel sensor while your getting these upgrades done (its cheap), you don't have to run ethanol with it but when you're ready to it's already there. Plus I believe the engine will run better being able to account for the ethanol that's already in 91 fuel. I'm no expert, this is mostly info I've picked up from this site and my tuner
#48 | |
Bottom line is we can spitball dyno numbers all day...but dyno's don't tell the entire story. If you want repeatable consistent power from a stock blower LT4 car, then it needs E.
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel Last edited by KingLT1; 05-27-2022 at 09:05 AM. |
#49 |
How often do you adjust the tunes in your and your brother's cars?
2020 ZL1LE A10.
#50 | |
#51 |
I made exactly 650whp SAE in Denver with regular Rotofab, Soler ported TB, ARH coated headers 1 7/8”, AWE catback, JMS Booster and flexfuel on an e70 blend. My local station blends to e70 at the pump so I didn’t have to do any mixing.
#52 |
So there are a few e85 stations close to me. How much would it be to convert the car to e85? I know some people mentioned it earlier. Or how much for that whole flex fuel sensor that automatically retunes the car for whatever I put in?
#53 | |
#54 | |
The ECM can then always find the proper stoich value for the actual percentage of ethanol in the tank that the sensor reads, and adapts fueling based on the tables, triggers and volumes set in the tune, thus all its (lambda-based) fueling calculations will automatically be correct all the time between the set ethanol percentages (typically 0% to 85%). As KingLT1 said, the rule of diminishing returns kicks in beyond E60, but since the energy density of ethanol is lower than that of gasoline, the more E you have, the more fuel volume the engine will need, so it may not be worth having enough (expensive) fueling capacity for E85, blending to never exceed E60 will give you almost all the achievable power. If you want the convenience of being able to just pump/fill whatever fuel and never worry about blending, it will cost you, because you must upgrade the fuel system to a supply capacity sufficient even for E85.
#55 |
Car has officially been dropped off. Wish me luck gentlemen!!
#56 |
Good luck
Also, your high density altitude will probably help go higher in E content than us valley and sea level dwellers.
| Tags |
| cai, cam, headers, mods, street build |
