Old 03-19-2022, 07:25 AM   #43
GXP08jrf
Drives: 2016 1LT 'Vert
Originally Posted by UnknownJinX View Post
On my 2 8th Gen Accords(08 Coupe EX-L V6 A5 and 08 Sedan EX M5), there is actually something similar to that. If you tap the unlock key once, and then again and hold down the unlock key, then you can roll the windows down and open the sunroof. Could be helpful on a hot day. The Camaro will also open the windows with this trick, but not the sunroof as far as I know.
Ok, so here's my hypocrisy on the baldness. My Camaro is a 'vert and my 4th Gen Firebird has T-tops. They're always open air when I drive them (unless a passenger complains about the wind).
That said the convertible top can be operated from the key fob, which lowers all windows as well. I'd be curious on what sort of wiring or computer logic would be necessary to have that button operate the sunroof. Although you'd still not know if it was open or closed without looking.
I seldom remembered to look up at the sunroof on my previous car to verify it's position. Over a couple of decades I've not been able to train myself to do it when I've had sunroof equipped vehicles. The 'vert and t-tops are impossible to not notice, so they always get closed/latched.
Thankfully, most of the time when I park, I look back at the car and hit the lock button to verify the security of the vehicle. Innumerable times I was walking back to the car, jump in and close that darn sunroof. If it was fob operable, it'd add a layer of convenience. Doesn't help for the times when I'm in a rush or otherwise distracted, and those tended to be the days it rained, they decided to mow the lawn, or power blow the dust and dirt off the parking lot. Lots of debris manages to make it through that slight opening when sitting still for 9 hours.
GXP08jrf is offline   Reply With Quote
Old 03-19-2022, 07:44 AM   #44
ALMN
ALMN's Avatar
Drives: 2SS 1LE M6, Palisade Calligraphy
Had a sunroof on my 2012 2ss rs ls3 camaro. It only looked good nothing more. Too small to give open top feel, sunlight in your face and eyes sometimes. Headroom was also an issue and had to deal with a rattle coming out of the sunroof. Ordered my 22 2ss 1le without it and will have no regrets.
ALMN is offline   Reply With Quote
Old 03-19-2022, 08:07 AM   #45
gpskinzhut
gpskinzhut's Avatar
Drives: 2020 Corvette Stingray Z51
Personally, I don’t have an issue remembering to close it since I pull the shade after parking and it won’t close if the top is open.
I do miss T-tops. That was one joy of the IROC; after work cruise home, tops off. Some classic rock or hair bands cranked. Lots of thumbs up on that car. From the versions of T’s on the 5th and 6th gen that I’ve seen though, I’ll skip them for this design
2020 Corvette 2LT Z51
2017 ZL1 A10: (SOLD) ||
2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD)
gpskinzhut is offline   Reply With Quote
Old 03-19-2022, 05:13 PM   #46
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
I have had 3 different Gen6 camaros and had sunroofs in all of them. I really like the sunroof, it opens up the cabin a lot. On nice days I push the button and let the outside in!
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 03-19-2022, 05:41 PM   #47
len_eng
Drives: 2024 Radiant Red 2SS, 1994 Z28,
I have had 2 gen 5s and this is my second gen6. The gens 5s all had sunroofs and my first gen 6 did not. This was one of the primary reasons I purchased my second gen6. When it is warm out in the evening or early morning, I keep it open. It is very airy and in Mass works much better than having a vert. When driving during the day it brightens the interior when the sunroof is closed. Between the sunroof and the Kalahari interior the interior feels much less claustrophobic than my previous black interior no sunroof 2018 2SS.
len_eng is offline   Reply With Quote
Old 03-19-2022, 09:32 PM   #48
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
I need sunroof. Makes it more airy and open feeling/more light. I open it for airflow in the summer. I do need A/C some of the time in the summer (20 hours of sunlight at low angle heats objects and buildings to some pretty amazing hot temps), but a lot of the time windows and sunroof open is perfect. Plus, it kind of adds to the black-on-white theme of my car.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 03-19-2022, 09:33 PM   #49
armycop71
Love my Satin Steel LT-1!
armycop71's Avatar
Drives: 6-Speed LT-1...
I remember one time in my '92 I forgot to latch the passenger's side T-top and accelerated hard on the on ramp... it flew twenty feet in the air and broke into 30 pieces in the median. Bad day...
2022 SATIN STEEL LT1
6-Speed Man|Carbon Flash Wheels
Technology Pkg|NPP|Satin Blk Pkg
ZL1 Rock Guards|Red Knee Pad Set
EOS Track Spoiler|EOS 1LE Splitter
PBC LT1 engine built by Debi Lewis
armycop71 is offline   Reply With Quote
Old 03-19-2022, 09:37 PM   #50
digitalfutur
Drives: 2018 Camaro RS 3.6 A8
To get my Camaro with the fewest possible options in the color I wanted, black over black, I had to get one with a sunroof, as it was the best deal available at the time. I only use A/C on very hot days, so the tilt-open does help with wind roar when the windows are down.
The external slide-back design means that it only exposes ~80% of the opening when fully open, and that's best when the sun can shine in directly...for 2-3 hours in the middle of the day...I have a full head of hair btw, so I don't melt. The best of both worlds though, is a retractable hardtop like on the C8 Vette.
So I do like sunroofs, but it's not deal-breaker for me if there isn't one.
digitalfutur is offline   Reply With Quote
Old 03-19-2022, 11:01 PM   #51
MR's 2SS
Drives: 2020 2SS Vert/M6/F250 SD
Not a deal breaker but I dont really like a hole in my roof.
We drove a 2021 hard top with sunroof and our 2020 vert.
From a performance perspective I dont like verts and prefer no sunroof.
But this is a cruzer and a fair weather DD for my wife who has wanted a vert for years.
Both cars were 2ss. The coup had magnetic ride and the coups have the additional rear diff cooler so the coup was the better car performance wise.
Oddly the coup had the stock seats while the vert came with Recaros.
Thats salesmen ordering cars with stuff they think will sell... as if its a mini SUV or something.
My wife is 5'2" and the Recaros slid farther forward. Both cars were M-6 and she was more comfortable in the Recaro pushing the clutch to the floor.
So we have the vert.
If I was ordering a Camaro ground up it would be a 1LE and no holes in the roof at all.
MR's 2SS is offline   Reply With Quote
Old 03-20-2022, 12:50 AM   #52
JoeCamaro444
JoeCamaro444's Avatar
Drives: 2018 2SS M6 Hot Wheels Camaro
I’m about 15 minutes south of you in MA, and I agree. My last 6th gen didn’t have a sunroof, and it felt a bit dark and closed off in there. Love that my current has a sunroof.
2018 2SS M6 Hot Wheels Camaro loaded (Moonroof, Magnetic Ride Control, NPP, etc…)
Previous cars:
2017 1SS Nightfall Gray Metallic w/A8 and NPP
1988 IROC-Z (tons of mods), 1995 Z28, 1998 Z28, 2006 GTO, 2010 Camaro 1SS, 2015 Subaru STI, a couple Acuras and multiple Jeeps.
JoeCamaro444 is online now   Reply With Quote
Old 03-20-2022, 01:14 AM   #53
Camaro fanboy
Camaro fanboy's Avatar
Drives: 2017 2SS Arctic blue fully loaded
not bothered myself. our hyundai has a full glass roof. half of it opens up.
never used it lol. just something else to go wrong.
Camaro fanboy is offline   Reply With Quote
Old 03-20-2022, 07:33 AM   #54
gpskinzhut
gpskinzhut's Avatar
I came close to something like that in my ‘87 when the center t-top rail rotted out and finally let go. Had to take the T’s off and get it home. My mom had a ‘92 Vette that she didn’t latch properly and the top launched when she was going down the road. Said that it came down behind here and, remarkably, didn’t shatter. She went back and grabbed it. Think she still has it in her garage lol.
Old 03-20-2022, 07:37 AM   #55
Realist
Realist's Avatar
Drives: 69 Project X2 & 80 Project Camaro
I daily drove my ZL1 and had the sunroof opened a majority of that time. Highly prefer and recommend a sunroof. I could go without if the car is just for weekends or if I ever opt for ZL1 1LE.
Realist is offline   Reply With Quote
Old 03-20-2022, 08:29 AM   #56
s346k
s346k's Avatar
Drives: like an old lady
sunroofs always look like afterthoughts. breaking up the lines and literally adding a hole to the roof. no thanks.
i've never bought a car with a sunroof and never will.
