Old 01-11-2022, 06:09 PM   #43
ember1205
Hot Camaro
ember1205's Avatar
Originally Posted by ariZona28 View Post
Nah, I'm just looking for an excuse to upgrade.
Oh. Well, then... you're spot on. There simply is NO WAY you can legally tow with the truck you have.
Old 01-11-2022, 06:26 PM   #44
ZL1plumbin
Drives: ZL1 1LE on order
OP. One thing to consider is usually the service body de rates towing a good amount due to the weight of it compared to a normal bed. Since GM manufactures it as a chassis cab. Not with the body on the back. Most times the upfitter doesn’t put a new sticker on it from what I’ve seen. Especially if it’s just some shop doing it aftermarket.
My vehicles that I have built to order with custom things on the back have diff stickers but that’s because it’s built at a factory and then delivered.
Just food for thought.
ZL1plumbin is offline   Reply With Quote
Old 01-11-2022, 06:49 PM   #45
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Yes for sure. Thanks
As the traitor FarmerFran mentioned I just need to get on the scale with truck and see the actual weight. Then I also want to see the weight of the car alone. Then when I get everything together hop on the scale with everything together. I feel I will be fine with all this discussion. Driving at a safe speed, tongue length figured out before purchase, possibly heavy duty brakes just to be safe. The open light weight aluminum trailer I feel is the key to success.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 01-11-2022, 06:54 PM   #46
ember1205
Hot Camaro
ember1205's Avatar
Just the fact that you're approaching this in a logical manner and working through things in steps tells me you'll ultimately land on a good setup that will [safely] work for you.
One thing I'll add for a suggestion for you to consider...
Buy the right trailer. If you end up determining that an enclosed trailer is right, figure out if you can load it in a way that will keep you within your weight limits. Just because that trailer "could" be loaded up to a total of 7k, 8k, or even 10k doesn't meant that's where you'll land. It will be a GIANT upgrade cost down the road if you end up needing to upgrade the tow vehicle AND the trailer at the same time.
Old 01-11-2022, 07:19 PM   #47
FarmerFran
FarmerFran's Avatar
Traitor? Wait WUT!?!?!?!
<Insert Cars You Own Here>
Old 01-11-2022, 07:35 PM   #48
BlackbeastSS2
Brother you are in a 392 now. Ok sorry maybe I should just refer to you as Benedict Arnold. All in fun, u had some good points in this thread. You should get back into an up coming killer 2023 ZL1 LT5.
Old 01-11-2022, 08:29 PM   #49
FarmerFran
FarmerFran's Avatar
If they make it, I will buy one!
Old 01-11-2022, 10:03 PM   #50
fj5gtx
fj5gtx's Avatar
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1
I have a steel 18 foot trailer 7k (bought new in 2005) with an incorporated beaver tail, towed it with a 04 1500 Ram QC with 5.7 hemi. The combo worked well. The 2500 is a better option if you're hauling often due to the heavier suspension and larger brakes.
Pick your tie down system in advance and have the trailer tie points placed where you need them when you purchase the trailer.
Get the trailer setup for a winch, you'll likely want it if you break stuff at the track.
Apply fluid film or similar product to the underside if you're in the rust belt, aluminum will oxidize.
If you plan to tow low cars, you may want to upgrade to a tilt trailer. More $, but they're nice and you're not messing around with ramps.
fj5gtx is offline   Reply With Quote
Old 01-11-2022, 11:20 PM   #51
laynlo15
Drives: 2022 Lt1 A10
So after pulling race cars for about 50 plus years and I've had about 15 trailers but when I started pulling aluminum trailers I was amazed at how much better they are compared to a steel trailer. Lighter, stop better, sit lower because the are torsion suspensions instead of leaf springs. They do cost more but are well worth the extra money. I just sold my 2022 Aluma for 1000.00 more then I paid for it. I'd never pull a steel trailer again or an enclosed like I had a few years ago when I worked for Magnuson. Spend the extra and you won't regret the extra cost. I always put a box up front to carry fuel, jacks, tools, etc.
Size:  190.6 KB Titan 24' enclosed
Size:  206.2 KB My Sundowner 20'
Size:  186.2 KB My steel trailer but the name slips my mind
Was trying to load my Aluma but for some reason it won't load.
Old 01-11-2022, 11:31 PM   #52
laynlo15
Finally my 18' Aluma before I put my box on I was test fitting everything getting ready to strap it down.
Old 01-12-2022, 04:43 AM   #53
BlackbeastSS2
Very nice Laynlo15 and thanks for taking the time to share. I am pretty much sold on the concept of an open aluminum trailer.
Old 01-12-2022, 07:48 AM   #54
laynlo15
When I had a enclosed it was nice for long weekends but the cost is higher and you'll burn a lot more fuel. Wind is an issue with towing enclosed trailers also even with a sway bar setup. The aluminum trailers tow so much better also and are generally several hundred pounds lighter then steel. Good luck on your choice.
Old 01-12-2022, 08:00 AM   #55
ember1205
Hot Camaro
ember1205's Avatar
This reminded me of a couple of things from my days of dragging snow trailers...
1) Aluminum trailers will still have steel axles. Different metals have to be 'insulated' from one another properly or they will deteriorate much more quickly. I had a set of main structural frame rails completely rot out on a snow trailer because the axle didn't have any material between the axle and the frame rails when the axle was mounted. Be mindful of how the trailers are put together and be sure that there is some sort of material between the different metals. Maybe even look at some much older versions of the trailers to see how the aluminum holds up over time.
2) A lot of guys would have the underside of their snow trailers sprayed with bed liner material (Rhino, Line-X, etc.) to keep them from rusting / rotting. Not sure if this is something that would easily translate for this type of trailer, but might be worth looking into?
Old 01-12-2022, 10:51 AM   #56
JSH
JSH's Avatar
Drives: '20 ZLE
This one works.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
