Old 02-10-2023, 06:16 PM   #43
Originally Posted by Blackmonba6Gen View Post
Well now that we got the baseline out of the way, now it’s time to focus on the finish line. The engine is out now. I wonder does this void my warranty
What is this "warranty" you speak of?
My powertrain warranty is about to expire next month, not that it was ever used or I'd even try with my mods... a technician doesn't even have to pop the hood to know my car is pretty far from stock, heh. A similar fate awaits you, I'm afraid.
Old 02-10-2023, 08:06 PM   #44
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
I must say I totally agree with you on that. The sound alone will be a dead giveaway! Good thing is I know how to do all the basic maintenance my self just like you I assume so no need to go back to the stealership
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is offline   Reply With Quote
Old 03-01-2023, 07:04 PM   #45
Blackmonba6Gen
BLUPRINT_1LE
Well, the results are in! 2 weeks later...
Below are the details of my package. I know, I know you'll are a big fan of MSD which you'll should in every right but I wanted to be the crash dummy and put my hard earn money where my mouth is to see how much potential I can squeeze out of this LT2 Manifold efficiently before making the change. Plus I figured, swapping the manifold & throttle body is a lot easier for me than trying to tackle a heads and cam job when I have Katech locally
I decided to choose the Katech K-Spec Heads and Cam Package which fit majority of my needs. I also added a few extra goodies which didn't come with their package but my budget allowed it for me to get the results I was looking for. Keep in mind, my results is based on 91 Octane not 93 Octane. Based on my assumption, if I put 93 Octane, I would've gain 20-25HP all round but unfortunately Arizona doesn't have 93 Octane.
140HP / 110 Tq over stock is not something I can say "meh" too. That's a huge difference.
I will let a Katech Rep chime in if there are more gains to be had in my package & share more details.
So far I am very pleased with the package. The torque this car creates over stock is insane. I know dyno numbers win the internet but dyno curves tells a different story and its a huge difference between mid and top end. SCCAForums car influenced me alot with my build so at least you can get an idea between the two which both was built by Katech to help sway your decision.
https://www.camaro6.com/forums/showthread.php?t=612790
Green Curve: Stock Baseline w/ LT2 Intake Manifold/Ported TB/Rotofab CAI w/ est: 8500 miles on Stock Tune
Blue Curve: H/C Package w/ 91 Octane
Red Curve: H/C Package w/ E85
Katech K-Spec Heads/Cam Package:
KATECH K-SPEC SERIES HEAD AND CAM PACKAGE, 575HP
MODIFIED GM LT2 INTAKE MANIFOLD (upgraded to MSD as of March 2024)
KATECH TORQUER LT1 CAMSHAFT 38%
660 LIFT PLATINUM GEN V LT SPRING KIT
GM LS7 LIFTER SET
GM LIFTER TRAYS
TREND 3/8-0.080 PUSHRODS
VVT LOCKOUT PLUG KIT
KATECH VVT LOCKOUT BOLT
KATECH CNC PORT CYLINDER HEADS
BASIC CYLINDER HEAD ASSEMBLY SERVICE
GM LT1 HEAD GASKETS
ARP HEAD BOLT KIT
AFM DELETE RIVOTS FOR ENGINE BLOCK
BRISK RACING SPARK PLUGS
GM DAMPER BOLT
KATECH 160 DEGREE THERMOSTAT
BASELINE DYNO
HPTUNERS CREDITS
STREET CALIBRATION
CHASSIS DYNO WORK
Additional Parts:
ATI Damper 10% UD
CHE Bronze Valve Guides w/ Valve Conditioning
Tony Mamo Stock Ported Throttle Body (91Mm) (upgraded to Soler Performance 103 TB as of March 2024)
Rotofab Dry Intake
Velossa Tech Air Scoop
Fueling:
DSX Flex Fuel Kit
Exhaust:
Kooks 1-7/8 Headers with Catless Connection to Stock NPP
Cooling:
Stock 1LE Oil & Trans Cooler
Misc:
Stock 1LE Wheels w/ SC3s
Track Wheels 19in ARC 8s w/ SC3Rs
Misc Spare Parts / Takeoff Parts
Oil & Consumables
5W50 Mobil 1
Brembo HTC64 Brake Fluid
GM OEM Rear Diff Fluid
Suspension
BMR Upper Trailing Arms
BMR Lower Trailing Arms
BMR Control Arms
BMR Rear Cradle Lockout Kit
BMR Front/Rear Sway Links
Videos will come later...
Next stage is let'ER eat!
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 03-02-2023, 10:27 AM   #46
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
527hp!! nice bro cant wait to see it on the track !!
Old 03-02-2023, 12:04 PM   #47
Blackmonba6Gen
BLUPRINT_1LE
I know right! Not bad for a heartbreaker dyno
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 03-02-2023, 12:14 PM   #48
FH212
FH212's Avatar
Drives: 2015 Camaro Z/28
That is the perfect power output. IMO.
2015 Camaro Z/28 - Red Hot
1978 Trans Am Y88 Special Edition 400/4 speed
2001 Mecham Trans Am #3 - 7.0L LS1
FH212 is offline   Reply With Quote
Old 03-02-2023, 12:35 PM   #49
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
Hell yeah man!! LETS GOOOO!!!
That1guy_tim is offline   Reply With Quote
Old 03-02-2023, 04:54 PM   #50
Blackmonba6Gen
BLUPRINT_1LE
Thanks! That's what I was thinking as well.
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 03-02-2023, 04:54 PM   #51
Blackmonba6Gen
BLUPRINT_1LE
Yessir! Its time to get straight to business
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 03-02-2023, 09:09 PM   #52
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
Dude!! That is nasssssty!
Old 03-02-2023, 09:36 PM   #53
atx_traveler
Drives: blue velvet
Gonna need some videos
atx_traveler is offline   Reply With Quote
Old 03-02-2023, 10:23 PM   #54
Blackmonba6Gen
BLUPRINT_1LE
haha that cat is out of the bag now, yes it is pretty nasty! Too bad im not in Michigan long enough to showcase it but maybe I'll come back during Dream Cruise to show it off a bit
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 03-03-2023, 08:02 AM   #55
Blackmonba6Gen
BLUPRINT_1LE
Videos coming soon.. Michigan about to get hit with some snow so I will be limited on drive time for now until it passes. I'll upload a cold start video once I get around to it..
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 03-03-2023, 09:32 AM   #56
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
527! Very nice, can't wait to hear the chop!
SSEssence is offline   Reply With Quote
