10-21-2021, 07:25 AM | #43 | |
Hot Camaro
If the problem persists, the CEL will likely come on and stay on, at least until better fuel is added to the tank to allow the engine to advance timing back toward where it should be. The reality is that an owner can put 87 in the T4 or the V8 and simply drive it that way, not caring about the warning lamps. And, it -could- cause damage if driven that way under for a while, especially under load. If someone were to buy a T4 or V8 without understanding the fuel requirements, and purposefully put 87 in the tank, they'd probably get rid of the car quickly because of it's performance (if they refused to fill with the correct fuel). It's always a toss-up on a used car. Hell... It's a toss-up with NEW cars. |
10-23-2021, 01:35 PM | #44 | |
Drives: Buick, Toyota Join Date: Aug 2021
10-24-2021, 10:37 AM | #45 | |
Drives: 2016 Camaro LT V6 Join Date: Oct 2021
10-24-2021, 01:36 PM | #46 | |
I do like the pre 2019 front end a tad better myself. Is it an auto or a manual? When you say you didnt like how the T-4 felt with the transmission, can you be more detailed? I assume you were able to test drive a new 4-banger at a dealer.....hmmmm. That means there is stock out there or did you test it a while ago? |
