#43 | |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
#44 | |
However it could help his case if he can find some documentation from the dealership stating that they did their inspection and the ECU was found to be unmolested and has never been tuned. It's a longshot but at this point it's pretty much the only thing he has. Even if the salesman and sales manager verbally told him that the ECU was never tuned, it will still be his word against them and they are not gonna fess up. He needs something in writing to that effect along with the ECU report proving he did not tune it. |
#45 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
My thoughts...
A. As far as the warranty goes, regardless if it's a 'full' warranty or not, You have to read the fine print to see just what the warranty covers. It's quite possible that the warranty covers any and all parts (other than normal wear parts), and IF the ecu had failed, it may be covered under the warranty. However I doubt that any warranty would cover the ECU because it had been re-flashed as part of a tune. It'll be interesting to see just how the OP's situation is resolved. My bet is that it'll be decided that he will indeed be responsible for the full cost of repairs. But then again that's just my guess. B. As far as GM is concerned, as soon as the ECU has been modified with a tune, it automatically voids the warranty. GM (I believe) checks some sort of a 'counter' that tells them just how many times the ECU has been flashed. Thus, a 'tuned' car voids GM's warranty. C. as far as passing the smog test, they are the ones that only require a stock tune. It appears as though the smog people don't care if the car has been tuned in the past as long as the original tune is installed during testing. As far as the selling dealer goes, it's quite possible that the original owner had the car tuned, then reinstalled the 'stock' tune. No idea if the original owner revealed this fact when he sold the car, possibly not. As long as the car had the original tune when it was sold to the dealer, the dealer would be able to get the car smog certified because tyhe stock tune had been restored. |
#46 | |
A lot of times dealerships will try to scam GM thru any number of means so the car will be covered for warranty work. However a lot of times an investigator will get sent out for any major repairs to make sure there is nothing fishy going on. I had a friend who had an engine blow on a ZL1 and an investigator showed up to the dealership to check everything. Luckily he was bone stock and it was covered. |
#47 | |
How could Ca. possibly decline a passing smog test if the car is stock during the test. I leave the "off road test pipe and tuner with cables in the bed of my diesel pick up during the test. San Diego no less. Not a small town as far as testing requirements go. I think I've passed six tests so far this way.
#48 | |
However, a police officer CAN pull you over, give you an on the spot inspection, and then have your car towed and fine you if they find it to be illegally modded or not road worthy or not street legal. Or they can remove your inspection sticker and give you a warning with a date to have your car reinspected by. They can impound your car too. Remember, a lot of these modifications are Federal offenses. I mean, it's not like they're gonna arrest everyone who mods their cars on Federal charges. But technically I guess they can. |
#49 | |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
#50 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
#51 |
I'd be more pissed they stole your money for an Extended Warranty. Doesn't matter who tuned it or when it was tuned the warranty was basically voided when you purchased it. This is where things like "Certified" pre-owned would have helped in this situation.
I got an on-star report on a ZL1 I traded in about a flat tire. Called my sales guy and he said they had to change the tires to get it to pass the certification process. I couldn't believe it since the tires were barely half worn. But yeah, you are pretty much screwed right now unless the dealer will make it right but it seems like they are scumbags that probably won't. |
#52 | |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Yes, putting the original cal back would allow the car to pass the test IF there is no requirement the original cal was modified.
#53 | |
For this, the dealer is required to submit a “snapshot” of the calibration file and submit it for comparison. GM apparently keeps a VIN based copy of the original. For reference, when I added a GM calibration and fuel injectors to my Saturn Sky Redline, they had to submit the new calibration file against the VIN. Of course this was 10 years ago and I think it’s much simpler with the counter used for the number of times the calibration has been changed.
#54 |
![]() Drives: 2021 Chevy Camaro LT1 Join Date: Sep 2021
Sorry if I missed something here, but the OP said he got a CEL for low oil pressure, loss of power and to stop driving. Had it towed and the dealer refused warranty coverage because it had been tuned. How did the conversation get turned to passing smog? Sounds to me like the oil level was low enough to warrant an issue with a supercharged engine and the ECM flagged it. Why not add or change the oil after the car cooled off and then try starting it? Unless he was driving it hard and blew the motor...
2021 LT1 A10
Borla S-Type, CAI Intake, BMR Springs MRR M650 Wheels Nitto NT555 Gen 2 Tires GM Splitter and Rear Spoiler |
#55 |
![]() Drives: 18 ZL1 - M6 Join Date: Mar 2019
When are going to get an update from the OP? Everyone is chiming in (with good info), except the OP. What’s the latest!?!?!
#56 | |
Thank you Al Oppenheiser!
Yes, if the only thing that caused the limp mode was low oil, then this is what the OP could have done before getting it towed in the first place. |
