Old 07-04-2022, 09:59 PM   #43
BlueStreak91
BlueStreak91's Avatar
Drives: 2SS Vert
I ran an update (as prompted) by the head unit last night when I got home.
Today I don’t have seat coolers anymore. Switch and lights for them appear to work.
I didn’t think to test the heaters, I’ll do that tomorrow.
Coincidence?
22 2SS Vert, RSB, White Stripes over Ceramic White w A10, MRC, NPP, and more (built in Michigan)
71 Chevelle (built in Texas), 05 Yukon XL (built in Texas), 22 Corolla Cross (built in Alabama), and more cars for the kids
BlueStreak91 is offline   Reply With Quote
Old 07-08-2022, 12:10 PM   #44
BlueStreak91
Drives: 2SS Vert
Further intrigue. Heated seats not working, but the switch shows them on.
I can hear the blower for the cooled seats running when the switch is on, but no airflow to speak of at the seat. Anybody know where I can find a page from the manual describing the airflow path from the blower to the seat? It acts like an airline somewhere developed a leak or got disconnected.
Old 07-08-2022, 04:53 PM   #45
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
They just suck from underneath. They are ventilated, not air conditioned.There is a tube that runs from under the seat to the bladder that the air blows out the little holes from.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 07-08-2022, 06:12 PM   #46
-Geoff
Yeah, the airflow is relatively weak even at max (level 3) speed. Turning the A/C on and blowing cold air down towards your legs will significantly improve it (if everything is working as it should, of course).
Old 08-04-2022, 02:19 PM   #47
Jarek
Jarek's Avatar
Drives: 2017 2SS Convertible
Fixed! Topic solved
Hello,
Thanks to the input from our colleagues raidaru and ejik418 we managed to find the root-cause.
All symptoms are connected:
- heating/venting not working
- unnecessary triple door unlock command
- driver's seat memory not working
The problem lies with the BCM and can be fixed with single command executed from diag computer.
Command is named "Read LIN Bus Device ID Information", this brings you to the list of modules but ignore them and go straight for the "Update" button - pressing it fixes all instantly.
I have attached photo from diag computer.
I hope it will help some other forum users (to avoid replacing modules or exchanging seats/modules with other working cars, or trying to look for error codes like 3 of us did).
Best regards,
Jarek
I am marking this topic as solved!
Camaro SS 2017 Convertible, 2SS trim, V8 6.2L 455HP 618Nm, A8, Silver
Mods so far: K&N oil air filter, rear lamps EU conversion with sequential turn signal, exhaust mod to 4 tips (non-NPP), LED rear fog light (EU requirement), Diode Dynamics LED markers.
Mods planned: Morimoto LED lamps set (front)
Jarek is offline   Reply With Quote
Old 08-04-2022, 02:48 PM   #48
Anjilslaire
Anjilslaire's Avatar
Drives: 2021 3LT RS A10
Where does one get the diagnostic application to run this? Assuming it's a dealer/mechanic exclusive?
Just being nosy as an infosec geek
Anjilslaire is offline   Reply With Quote
Old 08-04-2022, 02:55 PM   #49
Jarek
Jarek's Avatar
Yes - you need to have good mechanic for that - best specializing in electronics with proper tool set.
I assume mine has dealer level computer, however I posted the command name so that any mechanic can check with their devices if this is visible/usable for them (if not go to dealer).
BR,
Jarek
Old 08-04-2022, 08:17 PM   #50
Thanks for getting back to the topic with the solution, Jarek. Makes even more sense if what happend was that a module got replaced (at some point) and thus IDs didn't match before you executed this re-read command.
Old 08-05-2022, 04:40 AM   #51
Jarek
Jarek's Avatar
Hi arpad_m
In our case even after the module replacement of the module this command was not executed by the service people and problem remained (this was the case for ejik418 - until he went to dealer service) no errors were reported.
BR,
Jarek
Old 08-05-2022, 03:28 PM   #52
raidaru
Drives: 2SS
Tried that stuff that Jarek said it worked for him but I didn't get so lucky. After I execute that function it sends me to a sub menu of stuff related to windows and from there I can't do jack! Here is the vid https://www.veed.io/view/996f1e0a-11...6-172c9a20a10d
raidaru is offline   Reply With Quote
Old 08-05-2022, 03:53 PM   #53
Keko
Keko's Avatar
Drives: 2023 ZLE M6
The update command at the bottom doesn't do anything?
2023 ZLE M6
Borla S-Type Catback | Rotofab CAI | Soler TB | MPI Lid
2024 Polestar 2 AWD
Keko is offline   Reply With Quote
Old 08-06-2022, 09:02 AM   #54
Jarek
Jarek's Avatar
Hi Raidaru,
I double checked with my electronics guy today - and just as Keko suggested - it is the "Update" button that does the trick.
BR,
Jarek
Old 11-09-2022, 09:18 AM   #55
Jasonjay20
Drives: 2017 Chevy Camaro
How did you fix it
My car seems to do the same I can’t seem to find what the problem is! What was it that you changed out or fixed?
Jasonjay20 is offline   Reply With Quote
Old 01-26-2024, 11:51 PM   #56
Nine5gtr
Nine5gtr's Avatar
Drives: 2020 2SS 1LE
Just a follow up. I did what Jarek recommended and have a diagnostic tool to go through the bcm update. It populated all the models and all system back to normal. Anyone near me needs help, DM me.
Nine5gtr is offline   Reply With Quote
