#43 | |
![]() Drives: 18 ZL1 1LE Join Date: Apr 2013
That’s what I figured they were covering the welds. Thanks for the replies |
#44 | |
![]() Drives: 2019 ZL1 Join Date: Oct 2019
Looks fantastic
#45 |
![]() Drives: Turbo 6.2 Join Date: Feb 2019
love it
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
#46 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Those are the same Gesi Cores I used. 85200 vs 85230 with in-, and outlets. I will check how mine hold up in the stock location in a few weeks.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 |
#47 | |
#48 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Hahaha... I don't have much faith in these cats TBH but well see... I really hope these new ones are made better. Ill be scoping them soon to check
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#49 | |
Any chance of a startup and rev video? Would be great to hear the setup. I saw your old posts but the .MOV files are gone and cant be downloaded anymore. Cheers and thx! |
#50 | |
![]() I’ll get some idle and revs and in car sound.
#51 |
#52 | |
#53 | |
It’s not permanent if that’s what your asking.
#54 |
Yea I guess I was confused, how did they tune it with a wideband without removing the narrow bands if there is only one port pre-cat in collectors on each side?
#55 |
I’m no expert tuner by any means but here’s my take. Narrow band only contains info on whether it’s rich or lean. Wideband is just what it sounds like, can read very lean to very rich. This is what’s needed to tune properly as your getting the actual AFR and not just data from the narrow band which is a lean/rich condition.
#56 | |
Moderator
