Old 06-15-2021, 08:25 PM   #43
pbsinternet1le
pbsinternet1le's Avatar
Drives: 2017 1le current /2015 2ss 1le sold
Originally Posted by chenchbomb View Post
Can you please stop? At this point you are just spreading misinformation
Not true. Ask a knowledgeable tuner.
2017 1LE Hyper Blue
pbsinternet1le is offline   Reply With Quote
Old 06-15-2021, 08:29 PM   #44
pbsinternet1le
Originally Posted by pbsinternet1le View Post
It won't stall as the computer won't let it. Nothing to do with idle speed or cam.
Ask Mike at Vengeance.. he was the 1 that explained it to me. I don't care if y'all can't get your head around what I'm saying. It is there. I use it every day.. it is not the torque of the motor. Believe or not makes no difference to me..it works..
2017 1LE Hyper Blue
Old 06-15-2021, 11:43 PM   #45
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
What you've described does not exist on the 6th gen (ie. special "feature" that maintains engine speed at 1000rpm when letting out the clutch from idle with no throttle). Your videos actually illustrate it not maintaining 1000rpm. All that's in play is GM's idle speed control strategy (to maintain idle speed when external load such as alternator, AC compressor clutch, or clutch engagement as you've described) -- the difference in your case is that your idle speed was set much higher than stock. All cars have an idle speed controls strategy in play.
I'd love to hear the explanation from Mike on this feature, but I suspect you guys are talking past each other. There's a reason why you're the only one who believes this special feature exists.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
