#43 | |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
#44 |
#45 |
![]() Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
Here is my Callaway SC750 dyno on 93-95 octane. (Mix)
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, Auto Addict USA, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair, RacingBrake |
#46 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
With the extra custom tuning that I'm sure you paid Callaway dearly for correct?
Old Ride: 2016 Callaway SC630 Camaro SS
#47 |
No custom tuning from Callaway, the 618/633 is stock “hot” Callaway... 90+ degree temp during those runs.
The higher HP dyno is a custom tune on the car, for the higher octane when we are able to run it, still extremely conservative due to the extended track time. Best Regards, Dave
#48 | |
Kevin
Drives: 2018 Callaway Camaro ZL1 1LE Join Date: Apr 2018
That tune should be the same in my car or very similar. My ZLE was the first one done at Old Lyme, CT and was then run at Thompson Motor Speedway to test and refine that tune. |
#49 | |
#50 |
Kevin
The Hertz Callaway did not come with the supercharger exposed through the hood and therefore did not use the spacer. He had the spacer installed and hood modified to create a unique Hertz edition. The tune in the Hertz car was most likely more conservative due to the rental nature of the car. My tune was installed to bring it to normal specs.
#51 |
Thanks, exactly. And my car is an A10. Manual trans car would probably be a bit more.
Best Regards, Dave
