Old 11-29-2021, 09:14 PM   #43
BlaqWhole
Drives: 2017 Camaro ZL1 A10
I agree that the headers are not the most urgent thing to worry about right now. But I also agree that you really should opt in the 2" LTs instead of the 1-7/8s. I believe it was either SW or TSP or both companies that offers the 2" at the same price as the 1-7/8s. Either way even if it does cost a bit more you might as well go for it.
Another thing. I'm assuming this build is costing over $30K. Why not go for a TT setup and have even more potential down the road? You are gonna get to the point where stock displacement will hold you back. And then with more displacement you're gonna max out that 2650 or you'll be losing a lot of power spinning it. Just something to think about. I don't think you can go wrong either way tho.
Old 11-30-2021, 08:23 AM   #44
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The 2650 has made 1100whp @ 18psi sitting on top of a 427 breathing through 1 7/8 headers. XDI fuel system on E80 with no meth. Most builds don't even take full advantage of the 2650r around here.
Old 11-30-2021, 11:24 AM   #45
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Was that JRE's build? I remember a video he posted with numbers like that where he referenced another build that went out to 1200 or something, too. That's pretty stout.
'20 ZL1 Black "Fury"
Old 11-30-2021, 12:05 PM   #46
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Nope the lower pulley gets to big won't clear the xdi
Old 11-30-2021, 12:09 PM   #47
KingLT1
KingLT1's Avatar
Yes it was. I believe it was a manual car.
Old 11-30-2021, 12:39 PM   #48
Jwynn
Drives: Chevy Camaro
Yes King, It is a manual car.
How does 100mm upper and 8.3 or 8.6 lower sound for a starting point?
I ended up with a 70mm and 80 mm from Magnuson with the initial shipment...Long story.
So now I'll have to buy an upper. Question is, which one?
Jwynn is offline   Reply With Quote
Old 11-30-2021, 01:06 PM   #49
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Stick with the 90mm. You can buy one directly from magnuson or my personal preference would be to get the grip tech one.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 12-02-2021, 07:33 AM   #50
Corey7519
Drives: 2018 ZL1 A10
92 upper on mine with stock lower for now. Pully size, fuel limitations, throttle body, intake and so on all should have some type of impact on hp. Look up some tuners on here. Im sure they have some examples. One post I came across a while back - a guy in california put on a 2650 only because of emissions and gained aprox 100hp if i remember correctly and kept it inspector friendly legal. Maybe search for that post
Corey7519 is offline   Reply With Quote
Old 12-02-2021, 08:19 AM   #51
JANNETTYRACING
JANNETTYRACING's Avatar
Actually it does, I talked about that in one of the videos.
We installed a 9.17 on the bottom
www.jannettyracing.com
email tedj@jannettyracing.com
