#43 | |
![]() Drives: '18 ZL1 1LE Join Date: May 2020
Here's what I used from Amazon. It worked pretty well. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
#44 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
You might find wrapping those harnesses unnecessary. It it can't hurt but my Jet Hot 2800F coated 2" Kooks headers don't get that hot at all on the outside. I could easily touch them at full temp, I wouldn't leave my hand on them but they're cool enough to touch.
#45 |
Yeah, just one catch. Mine weren't coated and there was only around 3/4" between that harness and my headers so I wasn't risking it. There's well over 2-1/2" now so I feel good about it. Getting my headers coated is the only thing I would change if I did it again.
#46 | |
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
A good test would be someone who hasn't coated there headers to use a infrared thermometer to record some header temps. And compare them to jet hot and Swaintech. |
#47 | |
#48 | |
#49 | |
#50 |
Honestly I wasn't that concerned about the steel brake line. I can get my hand between that and the header and I don't track the car so I doubt I'll ever have an issue with it. The wiring harness on the other hand I've read horror stories about from folks that melted it.
#51 |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Did any of you guys end up installing those BMR engine mounts? I am interested in your after thoughts? My headers are getting coated now... Would be a good time to swap the mounts if the benefits match the website without any other downsides?
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#52 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
Yes I did as well as a friend. It made the 2” install much easier on the passenger side. I don’t see a downside as an after thought. I’m in an SS but don’t see how that makes a difference. As always, I could be wrong.
#53 | |
I understand the benefits to space... but am concerned about too much extra vibration or noise... so are you saying you haven't noticed any issues there?
#54 | |
![]() Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
Here’s a video “before BMR mounts” and then a video “after the BMR mounts install” just look at the Callaway blower movement before and after. I just went with standard Poly. Nice install and made headers install a breeze. Before BMR: https://youtu.be/1IGkoNHEkhU After BMR: https://youtu.be/LPKAjq_dsiU Best regards, Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, Auto Addict USA, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair, RacingBrake |
#55 |
![]() Drives: 2018 Camaro SS 1LE M6 Join Date: Oct 2018
I removed that brake line clip when I installed my headers. Slid right in from the top. Wrapped everything in DEI heat shielding. Funny though as I had mine coated locally for 250$. 10 min after parking it i can put my entire hand on the primaries without burning my skin off.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ |
#56 |
![]() ![]() ![]() ![]() Drives: 2018 ZLE Join Date: Feb 2018
Working with a lift allows better angles and adjusting. I did a Corvette a few months back and without the lift and doing everything from the bottom it would have been a disaster.
