Old 11-30-2020, 10:06 AM   #43
Tay
Drives: 1985 Oldsmobuick
Originally Posted by JANNETTYRACING View Post
Boost for boost you will likely not see any gain, the gain comes from more boost the new supercharger provides, when you are comparing blower only mods.
If your goal is 100-125 RWHP then no need to change the blower as you need these supporting mods before you do a larger blower.
This package is what I recommend you do before a blower upgrade no point putting more boost in when there is so much restriction in the current set up.
This package is what I run on my Personal ZL-1 and ZLE
https://jannettyracing.com/collectio...019-camaro-zl1
Hey Ted,
Just curious, why a 180 thermostat vs a 160?
Tay is offline   Reply With Quote
Old 11-30-2020, 10:16 AM   #44
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by Tay View Post
Hey Ted,
180 is the minimum Temp I would run any aluminum ls or lt engine.
The myth is lower thermostats make you run cooler but all they do is help the engine up to a minimum temperature.
The Fans and Radiator are responsible for top temp.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 11-30-2020, 10:28 AM   #45
Tay
Got it. Thanks!
Old 11-30-2020, 11:35 AM   #46
Mister Will
Mister Will's Avatar
Drives: 2021 Camaro ZL1 A10
Finally, hearing it from an experienced tuner.
Mister Will is offline   Reply With Quote
Old 12-03-2020, 02:57 PM   #47
LT4 650
LT4 650's Avatar
Drives: 2018 ZL1 1LE M6
Interesting package...I like everything except for the flex fuel part of it but I assume that is to run E85.
What if I did the same package without the flex fuel but ran 100 octane fuel (available to me at the pump)...what kind of WHP numbers would I expect to see?
BTW the pump gas where I live is crappy 91.
2018 ZLE - M6, Nightfall Gray
GM previously owned:
2014 SS M6
2014 ZL1 M6
2019 ZL1 M6
2016 Z06 M6
LT4 650 is offline   Reply With Quote
Old 12-03-2020, 03:14 PM   #48
JANNETTYRACING
There is nothing but positive about having a Flex fuel sensor on board even it you don't run E-85 fuels
Instead of assuming an E content %
Most fuels have Ethanol levels that vary some so if the ECM can see actual E content it will always run absolutely perfect.
100 Octane fuel makes 640 RWHP easy
Old 12-03-2020, 03:22 PM   #49
LT4 650
LT4 650's Avatar
Makes sense...thanks.
2014 SS M6
2014 ZL1 M6
2019 ZL1 M6
2016 Z06 M6
Old 12-03-2020, 03:29 PM   #50
Camaro#7
Drives: 2021 Wild Cherry ZL1 1LE, A10
Tedd,
What would be the downside of running this on a 2021 ZLE since the A10 is running the bosh module and is not able to be unlocked yet...or ever?
Camaro#7 is offline   Reply With Quote
Old 12-03-2020, 03:31 PM   #51
JANNETTYRACING
Originally Posted by Camaro#7 View Post
Tedd,
Too Early to say.
Old 12-03-2020, 03:32 PM   #52
Camaro#7
Hopefully someone will unlock it. I have never been a fan of tuning without also tackling the TCM portion.
Old 12-09-2020, 02:56 AM   #53
CamaroSS1LItaly
CamaroSS1LItaly's Avatar
Drives: 2020 camaro 2ss 10 speed
640 rwhp with you 125 rwhp package on 100 octane? Would be perfect
CamaroSS1LItaly is offline   Reply With Quote
Old 12-09-2020, 04:35 AM   #54
wnta1ss
Drives: 2017 Camaro 1SS
Be advised that when he says 100 octane, he means PON of 100 which is (Research Octane Number + Motor Octane Number) divided by 2, what we use here in the USA. I know that in some European countries they use RON instead, which is a higher number for the same fuel, example, 98 RON is probably not any better than 93 PON. So make sure that you compare apples to apples if using an octane recommendation from the USA in a different country.
Old 12-09-2020, 07:45 AM   #55
laynlo15
Drives: 2022 Lt1 A10
Teds right on the 180 and thats what I ended up with on my Camaro. Ran the 160 Mishimoto and it failed twice. These motors really need to come up to temp to make power and if they don't you can see some failures when you start hammering it too early. I had some issues on my Vette trying to run the 160 with the billet housing even though I made all the changes in the HP Tuners files especially with the AC, seemed like when running down the road with the AC on it set something off in the tune and the AC would go off and the fans would run on high until I reflashed it so I went back to the 194 TS. No issues since and I'll probably try the 180 next year. Maybe I missed something in the tune when I made the changes but I just didn't want to mess with it anymore.
camaro, magnuson, supercharge, zl1 1le tune, zl1 tune
