Old 12-01-2020, 04:06 PM   #43
KarmaKrush
Drives: Chevy Camaro
Basically the 2 screws holding the lift blocks on are just not enough to stop movement.
I paid 480$ to fix them today, I will never use a lift on my car again
KarmaKrush is offline   Reply With Quote
Old 12-01-2020, 04:52 PM   #44
Sorry, let me join the list of those who still don't understand. Those set screws do nothing when the car is lifted, their sole purpose is to prevent the lift pads from dropping when the car isn't jacked up.
The vehicle's weight is supposed to be sustained through the top of the lift blocks that touch the chassis next to the pinch welds, while the welds themselves simply serve as guides.
Someone tell me where I'm wrong. My car was lifted umpteen times at the dealership and tire shops, with these lift pads on it, with nary an issue.
Old 12-01-2020, 04:57 PM   #45
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Originally Posted by Invertalon View Post
Yeah, this. My lift pads 'bottom out' on the floor/frame above the rail, it's not just supported by the frame rail itself. Picture below is right after I installed them. The flat tops of the jack pads on the top 'frame' are what stabilizes the lift pad.
I see the pinchweld is bottomed out in the groove of the pad, but it doesn't look like the top of the pad is contacting anything. Are you sure it's actually butted against the floor?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 12-01-2020, 05:57 PM   #46
Allez
Allez's Avatar
From the makers of ZL1 Addons Lift pads - see the 2 minute mark.
The pinchweld is supposed to support the weight of the car, not the area around it according to this.
Allez is offline   Reply With Quote
Old 12-01-2020, 07:11 PM   #47
I see, thanks for the info Allez, it seems they do say the bottom of the pinch weld is what supports the car's weight. My ZL1 Addons lift pads do appear to butt against the floor, but I think the bottom of the slot is also in contact with the edge of the pinch weld, at least they are extremely close to the frame at both locations.
This pinch weld is one of those unintuitive designs that may be mechanically sound, but will keep confusing everyone to no end, because a few thin sheet metal edges will never appear sturdy enough to hold up 3600-4000 pounds without bending, welded high strength steel or not.
Old 12-01-2020, 08:01 PM   #48
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
100% agree ( confusing and somewhat concerning)
I ended up buying magnetic flat bottom jack pads, rubber slotted jack pads and permanent screw type jack pads. The permanent ones are still in the box. After reviewing the fitment / potential failure points, nothing about any of the products makes me say, wow I feel really secure. I’d never lay under this car and start tugging at things while lifted (even with jackstands). Personally, I like the flat bottom removable pad best for my type use. It seems to be the most secure for weight distribution, with its larger physical size and stable flat bottom (I’ll use for removal of wheels and brakes)
For me, under car work = Race ramps....
Old 12-02-2020, 01:56 AM   #49
Uk2019
UK2019
Drives: Camaro 2017 2ss/eu spec convertible
I agree that the pinch weld itself should be taking the weight. On my 2ss convertible, the genuine zl1 addons pads also contacted the area around the pinchweld instead of the bottom. The attached pictures show my solution. A few strips of aluminium cut and inserted. Also used the same strips to stop the set screws damaging the paint and causing issues with corrosion. I know they're flat at the end but any movement of the pads could break the paint. Underseal also applied and the pads attached while still wet to ensure no moisture will get under the underseal and cause more harm than good. Blue locktite used on the set screw threads. All still firmly in place after over a year and lots of lifts by floor jacks and garage lifts
Uk2019 is offline   Reply With Quote
Old 12-02-2020, 07:38 AM   #50
zaimer
zaimer's Avatar
Drives: 23 ZL1 6speed
I agree with this. Apparently we are some of the few. Lifting solely on the pinch weld makes no sense to me. I don't even see how that would be the best stability-wise either? As you had said, the screws are nearly useless as far as actually lifting the car. The ZL1 addons, that were made SPECIFICALLY for the purpose of lifting the car, make full contact.
So these ZL1 addons, that many have had no problem paying close to $100 for, are still supposed to be modified for proper use?
zaimer is offline   Reply With Quote
Old 12-02-2020, 08:30 AM   #51
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
I just ordered the ZL1 Add On lift pads for my SS Convertible and now I am wondering if I should install them. I am going to need new tires soon and is the reason I ordered them. I am afraid the tire installers will mess up my fenders. I don't think anyone on the forum has had any issues though with that with the lift pads. If they damage the fenders with the lift pads on I will be responsible for the cost of repair though. Guess I'll have to see how they fit. I do have their magnetic pinch weld pad and never had any problems lifting the car with my floor jack so I think they probably will be okay. A lift will put a lot less pressure on the four lift points than my floor jack on one since it lifts one whole side of the car or approx 2000lbs (convertible SS).
craigss50 is offline   Reply With Quote
Old 12-02-2020, 08:41 AM   #52
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Do a walk-around of the car with the service writer before they take it in. That's what I did when I got tires over the weekend. I also handed them a printout of an image showing the jacking points. They used a wide padded flat lift under about 5/6 of the rocker panel but it was back away from the front fenders, so did no damage that I have been able to detect. The fenders are just as they were when I brought the car in.
Emoto is offline   Reply With Quote
Old 12-03-2020, 11:14 AM   #53
MatthewAMEL
MatthewAMEL's Avatar
There is a lot of teeth gnashing about these pads.
They work. They are stable. There are far more stories about cars falling off jacks and stands without these than with them.
ALL modern unibody cars are designed to be lifted by the pinch welds. It's not specific to GM. My Honda's, Fords, friends Mercedes, etc...
I use them to lift my Wife and Daughters cars, my car, etc...
The set screw makes sure the pad stay attached to the vehicle. I have had mine on for 4 years and no issues through countless AutoX and track days. I have put my car up in the air so many times, I can't even begin to count. Well, so much I broke down and got a QuickJack.
Install and use them according to instructions and enjoy a reduction in stress when it's time to get your wheels off the ground.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 12-03-2020, 12:00 PM   #54
XAUSTD
Drives: ‘18 Camaro ZL1, ‘16 F150 S/C Coyote
Is ZL1 on this forum? I would like to hear a reply from them concerning these.
XAUSTD is offline   Reply With Quote
Old 12-03-2020, 12:38 PM   #55
craigss50
craigss50's Avatar
They would pretty much state what is in the video posted in this topic. What I would pay attention to is what Matthew has stated above. Nothing like a non bias user to evaluate. After reading his post I feel pretty good about ordering them for my 50 SS Vert which I am very picky about. However, on page 1 post #13 KarmKrush has lift pads and still they damaged his fenders so I will speak to the tech before I let them lift my car.
Old 12-03-2020, 04:16 PM   #56
Racerman27410
Racerman27410's Avatar
Drives: 2016 SS 2SS
The fender damage that i've seen doesn't come from the pinch weld lift pads . The dealerships use a two post lift that has arms that swing under the car. When the lifting pads on those arms are not adjusted correctly then the arms of the two post lift will make contact with bottom of the front fender
and bend them before the lifting pad makes contact with the subframe/ chassis of the car.
Has nothing to do with the strength of the pinch welds and everything to do with techs not paying attention to details before lifting the car.
Racerman27410 is offline   Reply With Quote
