#43 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Cool, so we are not too far off then as my numbers were uncorrected. Appx 20 - 25rwhp difference is my guess if i apply the STD correction based on my high humidity and temps that day.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
#44 |
my 750 is before applying the SAE correction. And i can only estimate temp, humidity, barometer as there isn't a time stamp on the paper he gave me. With SAE its closer to 770
#45 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
This is true, I've often heard all that matters is the track since you can't compare dyno numbers but the reality is the track has just as many if not more variables than most dynos. It is difficult to compare dyno numbers at different dynos though, the dyno is a good tool for tuning and good when you use the same dyno to compare mods. The track has its purpose also, inevitably that's what most people want to see is better numbers at the track but it doesn't take much at all to make the numbers worse, poor tires, poor track prep, poor weather conditions and there's no corrections at the track like there is on a dyno. |
