#43 |
![]() Drives: Camaro ZL1 Join Date: Jan 2018
They can build you any suspension you want including their full blown race suspension and prices are very reasonable. The only downside: it probably doesnt make sense to ship your car to Germany to be put on their suspension dyno. I would contact them in case I wanted to step up from the 1LE suspension.
#44 |
![]() Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
KW are shit in my experience. But to each their own. Couldn’t give me a set.
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair Last edited by SCCAForums; 06-18-2020 at 11:40 AM. |
#45 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
The front Ohlins damper assemblies are ~$3,800 each. The rear Ohlins damper assemblies are ~$2,000 each. The front springs are Hyperco 375lb/in (8") or 550lb/in (7") or 800lb/in (7") The rear springs are Hyperco 650lb/in (7") or 850lb/in (7") Front top mounts are ~$630 each Front spherical slide/plate assembles are ~$390 each. Rear top mounts are ~$1,080 each. |
#46 |
![]() Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500 Join Date: Mar 2012
As soon as I get done with work on the 20th, I will pull out my Quick Jack and put her up in the air and start checking for anything loose, you really can't see much with it on the ground and with all the panels in the way, I did put the stock wheels back on so when I take her to work tomorrow I will know for sure, has anyone tried to adjust the front springs, I haven't read on here if anyone has and if made any difference.
#47 |
#48 | |
#49 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
how did you get all that info? and nice the use hyperco i have them on my camaro aka yyz springs
#50 | |
Sarcasm loading --------
no issues to date.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
#51 |
![]() Drives: 19 ZLE A10,17 SS 1LE, 16 C7R,CT5V Join Date: Feb 2017
I had both front shocks replaced under warranty on the ZLE. I had the left front passenger "boink" or "boing". I had enough leak out of the brass fitting to get all over my inner brake caliper to where braking had gotten worse. (I wasn't aware I needed to check on this brass fitting)
Chevy took 4+ months to replace mine. I have 4100 miles on the car and 3k of that is on track. I am going to DSC Sport with Tractive RTx. They have a custom wiring harness to turn the ZLE into adaptive suspension with the DSC Controller well known to the ZL1 (mag ride) and Corvette Community. |
#52 | |
I do not know for sure. But based off of the various literature on the ZL1 1LE and the components, my guess is: 570-600lb/in front and 540-570lb/in rear. Again, just my best guess. I'm actually really surprised no one has had the ZL1 1LE springs tested and documented at this point. From Pratt & Miller. |
#53 | |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
#54 | |
For some reason, the number of "700" stands out to me from reading something about the ZL1 1LE rear springs, but I could never find out where that was mentioned. Last edited by Mountain; 06-18-2020 at 09:19 PM. Reason: double-checked my notes.... |
#55 |
![]() Drives: 2018 Camaro ZL1 Join Date: Dec 2021
Sorry to bring this thread back from the dead. Did anyone ever publish the OEM Frt/Rr spring rates for the 1LE's?
#56 |
Spring rates
I read that the fronts are 450 rear 900.
