#43 | |
![]() ![]() ![]() Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Totally understand makes sense. My understanding is that Elite PCV valve is used for any size can, does the same of port effect anything ? So my question is,what are guys with 750+ HP using Elite E2 Ultra or just the E2-X. Also does the size of the hoses matter -6 or -8. I know I'm probably over thinking this but my OCD kicks in and I also like to learn. |
#44 |
![]() ![]() ![]() Drives: 2019 ZL1 Riverside Join Date: Apr 2020
I would run the Ultra can if you're pushing 100 + hp more than stock, Elite would need to comment at what point the restrictor should be swapped out - and then you have to find a place to mount the larger can, that's the challenge
#45 |
![]() Drives: Chevy Camaro ZL1 Join Date: Apr 2020
While the size of the PCV port makes for interesting conversation, let’s not forget that Elite has a standing challenge to put their CC in series with any competitors CC for a certain distance then reverse the CC sequence and repeat. In both scenarios, Elite says their can will outperform the competition.
I understand that the results of at least one challenge are still able to be viewed here. |
#46 | |
What would be the ultimate Elite setup? I was thinking Black Braided Hose (what size), high flow check valves,(how many), flow restrictor. |
#47 | ||
#48 | |
![]() ![]() ![]() ![]() Drives: 19 Z06 Join Date: Nov 2011
Gone but not forgotten:
1974 Corvette Stingray 454 1986 Z28 2009 Mustang GT convertible 2012 45th 2SS Vert 2013 ZL1 M6 2014 Zl1 M6 2014 GT500 2016 Challenger Hellcat M6 www.youtube.com/c/garageking |
#49 |
The reason for the big difference is our cars require a 1/8" restrictor to keep flow around 3.5 CFM. Elite puts that 1/8" restrictor under the blower (its part of the valve), Mightymouse has it built into their can (I can't remember if its on clean or dirty side) I put mine on clean side line going to throttle body.
#50 | |
Now don't quote me but I think you need about 20"hg for a 1/8 orifice to flow around 3.5. If you are accelerating (not racing or anything) you are not getting 3.5 SCFM because you are going to be at less than 20"hg Its actually in my video, I made a remark somewhere. The flow is not constant after you install a catch can. The one commonality is that we all use the throttle body for suction. Depending on throttle position you get maximum vacuum at deceleration with throttle closed, then idle is next, then when you drive the vacuum gets less the more you press on the gas. At wide open throttle you have virtually no vacuum. Thats why Elite and me use that second line to take over when the throttle body pretty much has no vacuum. Where I installed my restrictor makes a big difference. 1st, at WOT the Elite system (secondary line) has to suck through the whole system (including the restrictor) In mine, the secondary line bypasses the restrictor so the secondary line has no restrictor (much higher flow) I did this for four reasons 1. I don't believe there is much vacuum there so we need all we can get (no way that secondary line is going to produce about 20"hg of vacuum), I believe that high of vacuum would collapse that rubber elbow going to the throttle body. We are probably getting a few inches at best so we need maximum flow. (less vacuum means we need a wider diameter to flow) 2. At WOT there is more blowby so you need more evacuation 3. Secondary line will pretty much operates only at WOT, or large engine loads, so its barely used. 4. I can adjust flow very easily by drilling out the restrictor a bit if I want. ZX-10R caught onto this. There is a pressure drop across the restrictor so things are different before and after it. If we want to get even more technical we have to remember the pressure drop across a restrictive opening is proportional to the length of the restrictive section, and inversely proportional to the diameter of that section. So movement of the restrictor can do a number of things depending on where it is placed. You have to take into all that feet of tubing you are installing under your hood, it will effect flow. (suck though a foot of garden hose and then try again when its 10 feet long - do at your own risk, I do not take responsibility if anyone does this, but you get the idea) Sorry for the delay in my responses guys I've been busy with a few other things. Its great to see the interest.
#51 | |
I completely agree with your comment regarding available vacuum at WOT in a normally aspirated engine. However, it would be my assertion that in a FI engine at WOT, not only do you NOT have any vacuum but rather a significantly higher manifold pressure, far above ambient (29.92”hg @ sea level) necessitating the need for a check valve to stop back flow. Furthermore, the SC at WOT probably creates vacuum in the intake similarly to what the engine creates in the manifold at idle. This of course, is only a supposition on my part. If what I’m saying is true, then it may not have been necessary for you to bypass the restrictor on your secondary vacuum line, though an excellent technique on a n/a engine. It would be interesting to see what a vacuum gauge placed on the secondary vacuum line at WOT in our LT4 engine has to say about it. Thank you, Chris Last edited by Chris 2018 ZL1 A10; 05-18-2020 at 09:21 AM. |
#52 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Nov 2009
v8, I'll answer each point below inside your quote:
"Great post but I will clarify a few things. GM designed the system to flow around 3.5 or so SCFM. They did this with a 1/8" restrictor placed inside their PCV valve, so with a 1/8" restrictor somewhere we can get that 3.5 SCFM The OEM size is 3mm, we go just slightly larger to meet the 3.5 CFM goal. That is slightly more than a stock engine needs, but not excessive. This works for up to 1000 hp plus FI applications. Now don't quote me but I think you need about 20"hg for a 1/8 orifice to flow around 3.5. If you are accelerating (not racing or anything) you are not getting 3.5 SCFM because you are going to be at less than 20"hg Its actually in my video, I made a remark somewhere. Correct. Anytime a NA engine accelerates, or is at WOT, vacuum drops to near zero, even though a tremendous amount of incoming air is enetering. This is due to the reversion pulses that are created by the cam lobe overlap. Exhaust valve is not fully closed before the intake valve starts to open. This aids in scavenging, but no real usable vacuum is present. So we use a secondary vacuum source that takes over when IM vacuum drops below the vacuum generated by the Venturi barb. The checkvalves will open and close automatically to always default to the strongest suction source. This then provides full time evacuation unlike most every other can that solely relies of IM vacuum for evacuation suction. The flow is not constant after you install a catch can. The one commonality is that we all use the throttle body for suction. Depending on throttle position you get maximum vacuum at deceleration with throttle closed, then idle is next, then when you drive the vacuum gets less the more you press on the gas. At wide open throttle you have virtually no vacuum. Thats why Elite and me use that second line to take over when the throttle body pretty much has no vacuum. Exactly. Otherwise you not only allow pressure to build during these periods, but your also leaving most of the contaminants entering in the crankcase to contaminate the oil and increase wear. A very critical function most can sellers do NOT take into consideration. Where I installed my restrictor makes a big difference. 1st, at WOT the Elite system (secondary line) has to suck through the whole system (including the restrictor) In mine, the secondary line bypasses the restrictor so the secondary line has no restrictor (much higher flow) I did this for four reasons 1. I don't believe there is much vacuum there so we need all we can get (no way that secondary line is going to produce about 20"hg of vacuum), I believe that high of vacuum would collapse that rubber elbow going to the throttle body. We are probably getting a few inches at best so we need maximum flow. (less vacuum means we need a wider diameter to flow) 2. At WOT there is more blowby so you need more evacuation 3. Secondary line will pretty much operates only at WOT, or large engine loads, so its barely used. 4. I can adjust flow very easily by drilling out the restrictor a bit if I want. ZX-10R caught onto this. There is a pressure drop across the restrictor so things are different before and after it. If we want to get even more technical we have to remember the pressure drop across a restrictive opening is proportional to the length of the restrictive section, and inversely proportional to the diameter of that section. So movement of the restrictor can do a number of things depending on where it is placed. You have to take into all that feet of tubing you are installing under your hood, it will effect flow. (suck though a foot of garden hose and then try again when its 10 feet long - do at your own risk, I do not take responsibility if anyone does this, but you get the idea) Sorry for the delay in my responses guys I've been busy with a few other things. Its great to see the interest." Excellent post! One thing to point out, the secondary suction source is NOT from a restriction of the air fliter. That would be a negative in so many ways. We use the Venturi Effect, capaple or generating over 28" of vacuum in ideal conditions, but here it is generally good for from as low as 2-3 to 6-8". Not the level of a belt driven vacuum pump, which is by far the best for a big boost build, but it is designed for the street. The size of the hose can make a difference as v8 pointed out as well, and the standard hose is 3/8" id, which os equal to -8. We also use -10 for the Ultra if specified, but the connections at the valve cover/valley cover (depending on engine) are all 5/16 id. Good contributions! And for the links that did not work, here is the oil analysis: https://hosting.photobucket.com/albums/j392/tech17/.highres/Falcon%20long%20term%20testing_zps7l9mvzrs.jpg And the disparity between can designs: We are on the right same miles, same vehicle, the other common billet can is on the left. https://hosting.photobucket.com/albums/j392/tech17/.highres/JLT%20LEFT%20RX%20RIGHT_zpsmltwd0tu.jpg I probably missed a few things, but ask more questions. |
#53 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
And I’m well aware of the potential effect(s)of valve deposition, in particular when first generation DI Audi’s needed to be cleaned ~30K miles. I agree that there “may be” a HP drop at some point in todays DI engines ....and that cleaning the valves “may help” But, until someone posts up some loss of performance / independent data, I’ll call out suspect performance commentary. |
#54 | |
You wrote "Furthermore, the SC at WOT probably creates vacuum in the intake similarly to what the engine creates in the manifold at idle." Not at all, and I'm not sure how to explain this without, but it doesn't. Once you use the throttle body vacuum, which we are all using, you have to look at the engine like its N/A as you are taking the vacuum from the behind the throttle plate. The vacuum under the booster is no longer available to us as we put a diverter valve in there. You are %100 right with the check valves, and I use them on my set up and you have them on yours. EVERYONE should have them. Once your engine uses the secondary line, that means the check valve is closed for the primary line, so it does not matter what is going on in the blower (very simply), or anywhere else..... all you have now is suction from the secondary line, ignore EVERYTHING else because your check valve has closed the throttle body off (remember this is your main source of vacuum, its gone now). So the question becomes, with the secondary line being the only source of vacuum do you A. Want to have it be restricted? B. Want more flow? If you think the secondary line provides enough vacuum then use a restrictor, if you think the secondary line does not provide enough vacuum then don't. I think I may have to do a video on the LT4 PCV operation LOL Seeing it all on a white board with some good editing may help, heck it may even help me because when I do my videos I have to really think them through and take my time.
#55 | |
If someone does a dyno run, then does pulley/tune on their car and gains HP its not really independent either, but we believe it.
#56 | |
This is also an argument to install the can in front as opposed to routing the hose around the blower (I used about 6 ft). As far as pressure drop, it's obviously flow dependent so I would need to run the numbers for 3/8" hose at 3 cfm |
