Old 03-25-2020, 05:17 PM   #43
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by Nabush View Post
My interrogation is will a 95mm non ported be better than a ported 87mm ?
Yes, 95mm all day over any 87mm TB.
Joshinator99 is online now   Reply With Quote
Old 03-25-2020, 07:31 PM   #44
Nabush
Drives: 2017 C7 GS M7 / 2017 Camaro SS 1LE
Originally Posted by 6spdhyperblue View Post
It says stock bottom end in his sig.
This would be impressive considering Katech need a fully built 427 LT1 to reach 700hp....
Nabush is offline   Reply With Quote
Old 03-25-2020, 07:49 PM   #45
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
LT1 820 HP NA Get the check book out.
You will need 14:1 compression. RPM set at 8500 and lot of goodies to hold that engine together.
https://www.enginelabs.com/news/buil...-lt1-with-lme/
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 03-25-2020, 10:29 PM   #46
Nabush
I'm staying cheap thanks
Old 03-25-2020, 10:58 PM   #47
oldman
Drives: SS 6 speed of course
its cool for OHV
Old 03-25-2020, 11:21 PM   #48
BlackbeastSS2
its cool for OHV
Maybe the occasional street drive. Mouth guard required at an idling stop light. Lol
Old 03-25-2020, 11:55 PM   #49
Nabush
I started to dig a little, and for example Tick performance says a 95mm is like 5hp more than a ported 87mm... Does not seem really worth it ...
Think I'm gonna first go with the CNC ported heads, then I'll review..
Old 03-26-2020, 05:53 AM   #50
Joshinator99
Moderator
The more the rest of your combo makes, the more the 95 will be worth over the 87...
Old 03-26-2020, 07:26 AM   #51
6spdhyperblue
Drives: 2SS 1LE
Also I hope you swept the cam on the dyno. Using values in the scanner don’t align with power output in this case.
Old 03-26-2020, 08:47 AM   #52
Nabush
On the 10-15 runs I made the rpm was taken out of the common of one of the coils. It was matching VCM scanner exactly.
Old 03-26-2020, 09:18 AM   #53
6spdhyperblue
Drives: 2SS 1LE
I don’t understand the rpm bit, what is matching? If you were doing this on the street how were you determining increase and descreases in power? I’m only talking about the cam angle tuning
Old 03-26-2020, 02:06 PM   #54
oldman
There are more than a few Integra builds running E85 with 14:1 CR, I think it is an interesting solution because it is very hard to push that engine past 275 engine HP from 2.1 liter (bored and stroked) on 93 octane 12.5:1. With E85 the car can be DD on 14:1 CR and able support the street cam. On a VTEC engine basically 4 cams, the street lobes put dynamic compression into the detonation zone. On a OHV or non-VTEC dynamic compression drops the CR in low mid-range to allow DD usage without detonation. Nutshell E85 is used to get the old B engine into the modern K engine HP range NA. I would have just swapped in a K24 2.4 liter and build it to about 300 HP NA, but I have a original Type R and there is some collectable value in the car.
https://www.autoblog.com/2018/10/01/...auction-63800/
Fuel economy does go down say from 28 MPG overall to 25 MPG on E60+. I always say it takes a lot of theory to make a 4 banger use as much gas as a V8.
Before I did (heads, cam, supercharger), I was thinking about (416, heads, cam, E60, 12.5 to 13.5 CR). Off the cuff the increase in size and CR would add 75 HP over any DD 6.2 liter build. About 1/2 the HP gain of a supercharger but way less complicated and way lighter. The bigger engine and the higher CR allows the use of a nice 110 to 112 LSA cam, so this build would be a very responsive, midrange torque monster. The larger engine size also helps in gaining compression without a complicated piston head design. It is interesting to note in the above build LT4 heads are used with their much large 65.47 cc chamber and they could still get 14:1CR. Humm, the piston looks to have a very high dome and maybe the custom head gasket is much thinner. I just don't know enough to understand why the LT4 head was picked (yes it is slightly more dense due to the rotary casting method), but a larger chamber usually is NOT picked on a E85 NA build.
Old 03-26-2020, 02:39 PM   #55
Nabush
If you were attentive you would have seen the dyno graph posted in the first page of this topic...
Old 03-26-2020, 03:08 PM   #56
oldman
I was just thinking an E50 mix with 91 octane would allow for a nice head shave / thin gasket combo say to 12.5 to 1 and that would bring up dynamic compression and may go a long way to help the OP's midrange power loss. I did talk about it before, so that would be an option. I just tossed 12.5 around. I don't know for sure but the factory gasket is heck of thick... looks like cometic makes a .028 thick one.
RockAuto shows the LT4 gasket as .055" thick, and the LT1 as .054" thick. That is 7 layer vs 5 layer.
So thinking out loud, 4" stroke would have an ideal .348 chamber height. so the cometic gasket alone would but that to .320 or 12.5:1 CR. Somebody check on my math.
https://www.onallcylinders.com/2015/...ratio-for-e85/
