#43 |
Drives: 2021 ZLE, C5 Z06 6.0L Procharged Join Date: Mar 2023
I recently installed my ARH 2.0" primary headers without removing the starter, steering shaft or the motor mounts from underneath the car using a lift.
I probably should have changed the motor mounts as I probably will remove them to insulate the passenger side steel brake line that is stupid-close to one of the primary tubes. I did remove the aluminum subframe brace and dipstick tube. |
#44 |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I had no issues installing on jack stands... But I also swapped the motor mounts at the same time, which provides better clearance. A fun days labor for sure... with tons of smiles afterwards
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#45 |
![]() Drives: '23 LT1 Join Date: Apr 2023
Brother, I have paused my entire project purely to inform you of this miracle:
After 3 long weeks on jack stands and an absurd amount of agony (many walls damaged, car fell off the jack stand) I am pleased to inform you that I have JUST measured the clearance from skid plate to floor and I am looking at a STAGGERING 19.5 inches. No sketchy wood blocks piled to the sky, nothing. Just a jack and a hockey puck. I just wanted to let you know. This is a big deal, I thought I was screwed. I managed to talk my way into borrowing some old fella's 3.5 ton jack (THREE tons??) and stands. I was expecting 15-16, so I'm happy. Anyway, back to work. Your words stuck with me because I couldn't figure out how to get more height width out wood (and it fell off last time I did that with only one 2x4 I'm not in a hurry to repeat that). Here we go. Havent even opened the hood yet and I've sunk 16 hours into this. Spent 5 hours just jacking it up. |
#46 |
![]() Drives: 2017 Camaro SS Join Date: Feb 2023
I just put a set on mine and by removing the pass3nger side valve cover it goes right in from top without taking the motor mount off or loose. I had just put the hurst shifter in last week so headers were a walk the park compared to the shifter.
