Old 02-11-2023, 02:42 PM   #43
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
Originally Posted by ramair00 View Post
Dealership here would not even perform the work if I wanted to install my own purchased ktech.
Warranty issues.
That is not correct, call GM customer care
george is offline   Reply With Quote
Old 02-13-2023, 08:38 AM   #44
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
We know there is two pumps and matching pans.. just need someone to compare the two.
As long as Gm warranty is paying, I am not touching it.
My dealer was fine to install aftermarket part, but cautioned that any future engine failure would then have asterisk and risk of being denied. Soo.. GM warratny replacement it is.
I'll drive it per expectation of a 650hp track capable camaro. At 3x cost of base camaro... i think GM had enough profit in there for cover future "oh shits"
ing for grip.
http://www.motorsportsne.com/
Old 02-18-2023, 08:51 AM   #45
george
ZL1 Driver
george's Avatar
Originally Posted by Katech_Zach View Post
I believe there are 9 iterations of the same pump for Gen6 Camaro. Minor changes in all, and improvements as they get newer, but the newest ones can still fail (although less likely).
Zach,
Logically, the updated pumps are using stronger metallic compounds. As stated earlier, there was a change in the use of metal compound. If that's the case, isn't that a failure of material workmanship when the pump fails?
Old 03-31-2023, 02:11 PM   #46
ctrlz
Is this documented anywhere?
The tensioner shoe breaks leading to timing chain rub is a problem that starts outside and works its way in.
the more common problem seems to be the cracked stator, which is a problem that originates inside the pump, with no external damage. I believe katech uses a billet stator for added strength. The pictures always show this thing cracking where it is notched. This one has the crack there, and a few other cracks, as it appears to have thrown a few vanes:
https://www.camaro6.com/forums/showp...0&postcount=11
