10-17-2019, 09:39 AM | #43 | |
We are currently doing another build now with the Katech system and 30 over injectors so that will be interesting to say the least. Ted.
www.jannettyracing.com
10-17-2019, 09:41 AM | #44 | |
We have done many builds using both the Maggie and Whipple with our cam package and LT4 fuel system we make 750 RWHP regularly and reliably for years. Yes I have done several 19s
10-17-2019, 09:42 AM | #45 |
DSX flex fuel sensor and JMS fuel pump voltage booster.
10-17-2019, 10:28 AM | #46 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
Do they have a 2650 for the 5gen ZL1 ?
10-22-2019, 11:02 AM | #47 |
10-22-2019, 11:53 PM | #48 |
Drives: 2018 ZL1 1LE Join Date: Apr 2018
Good stuff. That’s a REALLY “happy” dyno
2018 ZL1 1LE - Summit White
529whp Baseline / 760whp 762tq ARH Ceramic Coated LTH 1 7/8" \ ATI 15% Lower \ RotoFab Big Gulp \ Katech 103mm TB \ Ported Blower \ DSX Fuel System \ Flex Fuel E85 \ Custom Cam \ Dual Springs \ Corsa Exhaust \ Prospeed Heat Exchanger \ Cordes Big3\ C&R Racing Radiator \ LS3 Stat housing \ 160* Thermostat \ NX Lid |
10-23-2019, 02:48 PM | #49 |
Not sure how happy his dyno is. You and I have pretty much the same build and I made 756 rwhp on Teds Dyno. So very similar to your HP rating.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
10-23-2019, 03:36 PM | #50 |
Are you also cammed and E85?
10-23-2019, 08:37 PM | #51 |
Correct.
Cam, e85 (E58 actually), LTs, ported blower, NW 103 TB, Roto Fab Big Gulp etc
10-23-2019, 09:05 PM | #52 |
Well shoot. Glad I’m right where I should be then. Was thinking I was a bit low
10-24-2019, 07:43 AM | #53 |
I can assure you there is nothing Happy about my Superflow SF840 Chassis dyno, it has proven to be the most accurate Dyno anywhere.
Cars come off the dyno and run the numbers predicted HP-Weight calculator. Superflow is the Dyno all others aspire to be. Any questions please don't hesitate to ask. Ted.
10-24-2019, 09:18 AM | #54 | |
I do in fact have a question. Can you explain the long term effects of overvolting the in tank pump and why one would choose that route vs a low side system? Is it just a cost thing?
11-02-2019, 07:27 AM | #55 |
UPDATE 823 RWHP ON PUMP 93 848 ON PUMP 100
We changed out the Cam to a completely new profile I designed call The Terminator, and WOW
https://www.facebook.com/jannettyrac...7758226818452/ https://www.facebook.com/jannettyrac...0967787407661/
11-02-2019, 07:33 AM | #56 | |
We do however install JMS fuel pump voltage booster to the Fuel pump control module. This is basically a variable capacitor with intelligent circuitry. It takes whatever the system voltage is at the moment whether it is 12.0 or 14.5 and stabilizes it to a constant 14.5 volts, then when triggered by the gas pedal/or boost your choice, it ramps the voltage up to 17.5 volts. This give the FPCM the power it needs to control the fuel pump and provide the fuel needed for higher hp. This Idea has been around for nearly 20 years or more We have used them in our builds for over 17 years that I can recall and never once had a problem related to this method. Ted.
