Go Back   CAMARO6 > Members Area > Ask the Camaro Team
Old 06-28-2019, 01:15 PM   #43
Mosaic6SS
Drives: Camaro
Originally Posted by Norm Peterson View Post
As long as it's a honeycomb you're seeing and not just a louvered/perforated internal pipe, seems like it'd have to be a converter. That wouldn't prevent it from performing some minimal resonator function, though.
Ryephile's picture doesn't look like there's enough internal volume in those rectangular-ish cans to give much resonator function for half of 6.2L worth of crossplane V8. On closer look, there does appear to be some sheet metal heat shielding. I've only seen that technique used with converters because of the extreme temperatures involved (seen a variety of converters myself, from pellet types to 4" in/4" out, and I've tackwelded a few heat shields back together to stop rattles rather than replace otherwise good shielding).
Norm
That’s what I am wondering whether they are considered full cats or not. I think someone said that the honeycomb pattern is larger and plus the material is of a ceramic type. Which is also used for converters outside of the normal metallic type. I cut the resonator off my mustang to add an x-pipe and noticed it was pretty close to the converts and it had a heat shield. I have also seen a few threads that said the mufflers were louder once these 2nd converters/resonators were removed, it seems to be true from the before and after sound videos I watched.
Mosaic6SS is offline   Reply With Quote
Old 06-28-2019, 02:17 PM   #44
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
So you are admitting they are cats now? I'm not sure what a less than full cat is though???
Old 06-28-2019, 03:30 PM   #45
Mosaic6SS
Drives: Camaro
I was never against the idea that they are cats, just had my own opinion and wanted to get the rundown on the exhaust system from the Camaro engineering team. I don’t understand why some of you are hell bent on trolling this thread over it, really not that big a deal. However you have the right to your opinion so post on it’s good for the thread numbers.
Old 09-06-2019, 09:27 AM   #46
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
GM
I never said I believe anything. Just passing along what they said just like I did in a previous post about what GM said
People get on forums all the time trolling and pretending to know what they are talking about i.e. see https://www.camaro6.com/forums/showthread.php?t=556536 for a clear example of this
It’s always wise to verify information no matter the source.
What did GM say? Are you labeling the dealership you spoke to as GM?
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 09-06-2019, 01:17 PM   #47
Scraps0f
Drives: 2018 NGM ZL1
No, they are labeling a worker at the dealership as GM engineering department public relations specialist.
Scraps0f is offline   Reply With Quote
Old 10-02-2019, 02:06 PM   #48
Osbornsm
Drives: 2018 SS 1LE
Consequently, an entertaining read i must say.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
