#43 |
![]() Drives: 2016 Silver Ice Metallic SS Join Date: May 2017
So out of curiosity, i am going to be installing TSP 1 7/8th headers would the mid pipe fit with the off road connection pipes? I am new to doing these kinda of mods and this would be a great money saver instead of having to pay 500+ for just a mid pipe. Thanks!
#44 |
![]() Drives: CMaro Join Date: Sep 2018
Got your 2in headers and x pipe kit and everything fit like a glove !
#45 | |
![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2010
How easy/difficult was the install? I’m guessing you had a lift available?
2007 Colorado I-5 3.7L z85 2wd ext. cab --Totaled 2004 Silverado single cab 4.8l v-8 2wd -- Traded 2018 Camaro SS 1LE -- Current DD |
#46 |
![]() Drives: 2018 Camaro SS Join Date: Mar 2018
I want to get the x-pipe kit to go with a set of LG headers I have installed. What distance apart from each collector on center will it work with? Thanks
#47 | |
"Thank you for your interest in our products. Unfortunately, we do not have the measurements from collector to collector. Thanks Marcus" If anyone happens to be under their car anytime soon, could you please measure the distance from the center of one collector to the other So I know if it will fit up with my LG headers? Really would be appreciated. Thanks |
#48 |
![]() Drives: 2016 Hyper Blue Metallic 2SS Join Date: Oct 2017
Does anyone know the thickness of the primaries for the 2"? I was going back and forth with their ebay rep but he didn't know and made no effort to find out. I know TSP claims 2mm thickness.
#49 |
![]() ![]() ![]() Drives: 2019 zl1 6 speed Join Date: Jul 2017
Now, only if the offered a catted version of this.
#50 | |
#51 |
![]() Drives: 2018 hyper blue ZL1 1LE Join Date: Nov 2018
Guys, I'm in the middle of this install and it's not going nearly as smoothly. I have an 18 zle with kooks 2" lth and green cats. The x pipe and rear section bolt up fine, but the front off road pipes ain't fitting. There are two big problems. The first is that the radius at the heat shield to connect to the green cats is to tight. If I push up the x pipe into the tunnel so that it doesn't hang down then the off road pipe hits the corner/heat shield and the diff cooler line. Secondly to get anything to clear means the entire set up hangs down probably 3".
#52 |
Well I got it installed. Going to go to the muffler shop to have everything welded in place due to leaks, but I was able to make it all work. The cross member under the stock x pipe won't go back in because the new set up hangs below the stock level. The stock mid pipe actually raises up and tucks into the tunnel. The new x pipe doesn't have the contour of the stock pipe and is lower and straight. It doesn't hang lower than the kooks headers though so I think we're ok. Fitting the off road pipes to green cats is not cut and dried. Luckily my buddy has a 4 pay lift in an air conditioned garage so the process wasn't miserable.
#53 |
![]() Drives: Camaro Join Date: Apr 2019
Why are these headers so cheap?
2018 1SS 1LE
Intake, P&P IM and TB, off road X pipe, 1 7/8 headers, 3inch pipes to npp, E85 BMR upper control arms, BMR trailing arms 12.0 |
#54 |
![]() Drives: 2016 camaro ss Join Date: Nov 2018
For those who purchased this, how are the holding up?
#55 |
![]() Drives: 2017 ZL1 A10 Join Date: Sep 2014
Were there any dyno results on these? I had a set on my 5th gen and loved em. Looking at starting to mess with my 19 and figured this would be a good place to start
Current: 2017 ZL1 A10 previous: 2019 1SS A10 previous: '14 L99, CAI intake, vmax ported tb, e85 kit, stage 2 cnc heads, speed engineering long tubes, custom high flows, resonated x pipe, muffler delete, qtp cut outs, gpi ss3 vvt Cam, zl1 pump and injectors, fti triple disc, mayhem motorsports trans cooler and tune, ngk spark plugs +red msd wires, 3.91 gears. Past: '12 LFX, full bolt ons + E85, 302hp/267tq |
#56 |
![]() Drives: 2019 Camaro 2SS 1LE Join Date: Jul 2019
Sean, I am also interested in this kit. Any update on when it might be available?
2019 2SS 1LE
