Old 12-04-2018, 04:37 PM   #43
Mountain
Mountain's Avatar
Originally Posted by ctrlz View Post
Since you are disconnecting the battery, you might as well hook up an ammeter and see what the draw is under various conditions. This will measure up to 10 amps DC:
https://www.amazon.com/dp/B01ISAMUA6...543951854&sr=1
I have a nice Fluke DVOM.
Yeah, I should have actually measured my parasitic drain (mA). Winter laziness... If my issue doesn't go away, I'll dive into that.
Old 12-04-2018, 06:34 PM   #44
Mountain
Mountain's Avatar
OK, so, after 24 hours, the battery hooked up and not starting the car, I dropped 0.03V.
Started the car, and let it run for a good 15+ minutes (some idle, some held RPM, some slow revving). Shut it off and checked voltage at 12 hours and 24 hours: 0.00V drop and 0.04V drop.
This is significantly better than before.
Old 12-25-2018, 06:36 PM   #45
Adrian97c
Adrian97c's Avatar
Drives: Wife's 14' IS 250
Car struggled to start last week, since then each time I start car the display says “lower & raise window”. I have to do this each time I start & today the seat memory isn’t adjusting upon starting. When looking at the battery voltage display it seems to bounce between 11-12, sometimes it’ll hit 14, but rare.
Any ideas? This battery is almost 1 year old. original battery died at about 16months.
-11% tint all around
Ordered • 2/06/16
Built on • 3/22/16
Adopted • 4/07/16
Sold on 2/05/16:
-Borla ATAK catback
-Range AFM delete
-15% tint all around
-Red LED interior bulbs
-55k white Cree LED fogs
-License plate LED bulb swap
-12" Sub Kit, BA amp swap
Adrian97c is offline   Reply With Quote
