#43 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
We are always happy to consult with you one on one and get you your perfect set up. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#44 | |
![]() Drives: 2018 2SS HBM Vert Join Date: Dec 2014
I agree with Drsagacity about the G2's. I went from running 555R to G2's on my 5th Gen and they were the worst, couldn't grip for anything. I mean even at 50 if I hit it would break loose. The reason I changed was my car was a DD (under 600 hp) and I guess I left the 555R's on too long and went into a bad spin in the rain on the Interstate doing 40mph. Plan on putting the 555R's on my 6th Gen once I get compatible rims. They hook pretty good, offer a smooth ride and aren't bad on the street. Just need to watch the tread, 70 miles a day for 11 months was way too long without replacing them.
#45 |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
The problem I discovered is nobody makes a DR in a 305/30. If I go with a 305/35 and my currently front @ 275/35 will cause the Stablitrack / abs whatever to go bizerk because the diameter between front and rear are too far apart. So like Drsagacity I would have to change my front as well. :(
#46 |
Toyo makes a R888 in a 305/30. It's a R compund so it will night and day better then a street tire.
#47 | |
![]() Drives: '18 SS 1LE M6 Join Date: Feb 2018
I tried driving without turning them off just to see what would happen... Def won't be doing that again.
'18 1SS 1LE M6 NGM|| 11.5:1 Diamond Pistons || Callie's H-beams || Vengeance III Cam Kit || Built Heads || TSP LTs 1 7/8"(C-Coated) || MSD IM || DSX E85 || Rotofab || BMR Springs || 576/472 @7000rpm
#48 | |
#49 |
![]() ![]() ![]() ![]() Drives: Black 2017 Camaro SS 1LE Join Date: Dec 2016
Tirerack has these
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
#50 |
I could see tire cost coming into play if you routinely track the car and go through tires a lot. In that case you would be best served to drop down to a smaller wheel. Ideally you want more sidewall then what a 30 series offers. 35 minimum and 40-45 series would be ideal for higher horsepower cars. Height and side wall make the biggest difference for straight line traction.
#51 | |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
As a result, I am thinking I will switch to 19’s, go with the Nitto 555R’s and then just sell my current tire setup. . .or wait and add the Toyos or Hoosiers on rear for the street and use the 19’s for the quarter mile runs. I am absolutely not a fan of disabling any sort of stablitrak setup. I am betting I can get really close to a 9 second slip with the 19in wheels and some 555R’s.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
#52 |
I have posted in this multiple times. I have not seen anyone use these tire on the quarter mile track. I probably put 4000-5000 miles on the Camaro per year since I only take it for local driving around town...I really wanted the Hoosiers to work. I figured if they were good for autocross they have toys doe everything the car can throw at them, right?
My guess is that they won’t be very strong at the drag strip.
#53 |
R7 is not streetable IMO. The R888 are barely but are.
#54 |
I didn’t realize you had run the R7’s. Did you ever run them for the quarter mile?
#55 |
Once these wear out I'll put Nt05s on for normal street use, and get a set of 19/18 F14s w/10.5x27" hoosiers for the strip and fri/sat nights.
#56 | |
As an aside the 888R's tread looks a bit like the Dierezza II that I run on my Type R. And yes that tire is OK in the rain.
