#43 | |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
1. What MPH difference do you see in the quarter mile when running 20in DR’s compared to running a 17in DR. 2. What about ET? I suppose I will do the experiment myself if nobody else has real data for comparison.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
#44 | |
The Gen5 ECM's have both a Stoich and flex fuel spark table(That need to be setup correctly prior to running E) which are both based off of ethanol content. Once the FFS sends a specific frequency to the ECM telling it basically how much E content is in the fuel, these 2 tables are referenced to adjust the timing and fueling correctly.
#45 |
![]() Drives: 2017 2SS Redline Join Date: Mar 2018
Even 0-60 or 1/8 mile differences would shed some light on the best path to take for 20" vs 17".
#46 |
![]() ![]() Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
I am not exactly clear on what you guys are trying to find out. A 28" DR tire (whether its on a 20-18-17-16 or 15" wheel) will net you the same result, provided traction is taken out of the equation. Your car is still rolling on a 28" regardless.
#47 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 Zl1. '18 GT350. Join Date: Dec 2016
R888R's aren't holding a +50 hp bump. Makes no sense. Those tires grip up until the 750 hp range, then they start cutting loose.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
#48 |
![]() Drives: 6th Gen NicKey Camaro & others. Join Date: Nov 2015
Going back to the OPs original question...... the appropriate DRs on 20s will hook hard enough to just about pull the wheels and will hook way beyond stock HP levels. I have run 10.30 -10.40s with 1.60fts with 20s all the way around.
#49 |
Also, I run e85 : )
#50 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
17 inch wheels all around will save you ~80 lbs. In rotating weight. That’s worth at least a tenth. Probably two. And that’s with my cheap heavy race stars
#51 |
![]() ![]() ![]() Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
#52 |
I do not believe that is the case because of different sidewall size and because of the weight difference for rotating mass...so, I am interested in empirical evidence to understand what I am giving up if I run on 20’s vs 17’s.
#53 |
Stefano, what mph are you trapping? You might have the best datapoint.
#54 | |
BAMF SS
20" rear wheel = 32.30 lbs 20" nt05 tire 275 35 20 = 30 lbs So a 20" drag radial setup weighs ~128 lbs 17x9.5 racestar = 20 lbs each 275 50 17 drag radial = 29 lbs (it's a little taller than the 275 35 20). 17 drag radial setup= 98 lbs So that's a difference of 30 lbs. The general rule of thumb is that 1 pound off the wheel is worth 3 off the car.... so it's like taking 90 pounds out of your car. And the rule of thumb is that 100 lbs is worth a tenth. That's obviously just a rule of thumb... weight effects each car differently. So since one person on this forum cut .2 off their et, doesn't mean you will. If you want to go really hardcore... a 15x10 wheel weighs in around 10 lbs, and a 28x10.5x15 tire is again 29 lbs. That's 78 lbs. So that's like cutting 150 lbs from the inside of your car.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
#55 | |
![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
That 1lb is worth 3lbs is a little high. Here is a thread with some links to the math. https://www.camaro6.com/forums/showt...ght=Rotational It is closer to 1lb is worth ~1.6-1.7lbs when talking about rim/tire combo. Still a huge deal to drop wheel weight.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
#56 | |
All I was stating is that a 20" DR can perform the same task as a 17 if lack of traction is not a factor. I'm not trying to toot my horn, but I have made over 175 passes in 2 1/2 seasons and have made many passes on both setups, I think it's safe to say I have more experience with both setups more than anyone on here. A 1.58 I believe is the best 60' I made on a 20 before I went to a complete 17" drag pack. I am now in the 1.4's but I have bumped up the mods so I cannot give you an apples to apples comparison, I still have my 20's sitting in the garage...maybe I'll swap them one day and see if their is a difference. I hope this helps, good luck with whatever route you choose. I look forward to your results.
