Old 10-26-2018, 05:03 PM   #43
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Originally Posted by Provoste View Post
Thought you guys might appreciate an update. I now have 7 days on track on the new setup and couldn’t be happier. The RS4’s have matched or beaten my times at Mid Ohio and Watkins Glen on RE71R’s (295/30 20” on OE SS 1LE wheels), and the wear is hard to believe. The tires look like they’re seen 1 day on track.
As for comparison to OE GS3 and RE71R- a tad more grip than the Goodyear’s, maybe a tad less than the RE71R. The RE71R might have a slight edge over the RS4 in a qualifying lap scenario- but the RS4 is the better track tire. The RE71R still reigns supreme as the best wet track tire I’ve ever driven, though the RS4 holds its own in the wet. They are more consistent than either over a 20 minute session, and the 305 with 10.5 square setup is just fantastic. Front to rear grip is wonderfully matched, and due to the et22 offset, the rears are pretty punched out, giving a wider rear track which aids stability as well.
Also, they’re a MUCH better road tire than the RE71R. They’re about as quiet as I remember the Goodyears, I drove to/from NCM last week for CamaroFest... great ride comfort, low NVH.
sizes!
What tire to use now that the RS4s are out of stock?
Old 10-26-2018, 05:50 PM   #44
TrackClub
TrackClub's Avatar
Absolutely nothing wrong with stockers if you run oem rims.
Old 10-26-2018, 08:10 PM   #45
carguy55
carguy55's Avatar
No kidding. You answer Provoste questions all the time?
Old 10-26-2018, 08:34 PM   #46
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Luckily I have enough left for rest the rest of this year.
If I needed tires, prolly RE71R. Running a true square setup like the 10.5 square would help longevity being able to rotate fronts and rears. The RE71R just HATES to be overdriven. If you slide them around in a heavy car like ours... they disintegrate. If you don’t hoon it around- they’ll last a reasonable amount of time (nothing like an RS4, but better than the Goodyear G3R).
Provoste is offline   Reply With Quote
Old 10-26-2018, 09:57 PM   #47
TrackClub
TrackClub's Avatar
Yes. Fyi: He pays me a handsome commission for my efforts
Old 03-20-2019, 10:08 AM   #48
jpdaugherty
jpdaugherty's Avatar
Drives: 2017 Camaro SS 1LE
RS4s finally arrived! And the Apex SM-10 19x10.5s look sooo good!
2017 Camaro SS 1LE
IG: pdaugherty7
YouTube.com/PatrickDaugherty
jpdaugherty is offline   Reply With Quote
Old 03-20-2019, 11:02 AM   #49
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
If you don't mind sharing what was the total cost?
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
Old 03-20-2019, 11:48 AM   #50
jpdaugherty
I bought the wheels last year when they were on sale. Now they're $469 each, tires are $335 each. Used the TPMS sensors from the stock wheels since I'm not going to be using them.
Total: $3216 w/o shipping
2017 Camaro SS 1LE
IG: pdaugherty7
Old 03-20-2019, 01:11 PM   #51
Provoste
Provoste's Avatar
Looks awesome!
Old 03-20-2019, 02:36 PM   #52
TrackClub
TrackClub's Avatar
Looks awesome!
+1!
Old 03-21-2019, 06:09 AM   #53
jpdaugherty
Thanks guys! Anxious to see lap time differences at AMP. Going to Road Atlanta this weekend with Chin.
2017 Camaro SS 1LE
IG: pdaugherty7
Old 03-22-2019, 01:32 PM   #54
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Getting mine mounted up after work today, then getting ready to head to VIR with Track Daze on Monday/Tuesday!
Provoste what kind of Cold/Hot pressures do they like? And should I rotate them at the end of the day Monday or just leave them be for Tuesday?
IG: @NC_M1SS1LE
Old 03-22-2019, 03:18 PM   #55
Provoste
Provoste's Avatar
Guessing lap times won't be massively different- .5-1.0 seconds faster I'd guess. However, you'll love how neutral the car is, and the ability to rotate corner/corner... plus I do like the friction circle better, they recover very quickly if you get them a little greasy/hot.
Old 03-22-2019, 03:20 PM   #56
Provoste
Provoste's Avatar
26ish to start.... They seem to like around 33- 34 hot. Nah, so long as you have enough negative camber up front they'll be fine for 2 days. Its hard to overstate how well RS4's wear.
