Old 06-20-2018, 02:52 PM   #43
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Originally Posted by Mcardenal View Post
I noticed the drop down offer both a single valve or dual. All the ones I see pictures of are the dual. What is the difference?
Dual is recommended for extra crankcase pressures generated by forced induction.
2018 ZL1 1LE sw/PDR
Old 06-20-2018, 03:48 PM   #44
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
If you retain the factory Clean Side Separator (and the OEM one is pretty good), you do not need our Clean Side Separator.
The single valve uses only the blower vacuum to evacuate, dual valve uses a second suction source to ensure enough suction is pulled to avoid pressure issues when needed most, at WOT.
Elite Engineering is offline   Reply With Quote
Old 08-12-2018, 05:20 PM   #45
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Installed mine
Tx elite
Question
I reversed the fixation of the catch can to set it more in the back
Need room in the front for the next mod ( supercharger extra cooling tank )
So now the elite mark on the can faces the back and not the front.
I respected the connection left and right, reversing for the T and the intake.
But,
I ‘ m sure both can be either one or the other because they only play succion...
The one in the middle is the in coming from the PCV,
The other 2 are only succion right?
Thanks to confirm I can plug them either T or intake or the other way
Appreciate
Biscuit.fr is offline   Reply With Quote
Old 08-13-2018, 09:45 PM   #46
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Originally Posted by Biscuit.fr View Post
Installed mine
Tx elite
Question
But,
Appreciate
Biscuit, can you post a couple of pics of your mounting bracket and location? I’m interested in seeing how you have it configured, thanks
Old 08-14-2018, 11:22 AM   #47
Biscuit.fr
Hi everybody
here is my catch can install where I reversed the fixation to push it the further aft....
and dremel is your friend ...
first : I had to round the corner of the fixation to clear the second bolt of my bar, repainted it in black after;
Second: I made my own tool in order to tight the new PCV Valve into the engine
hope it gives you some ideas...
then I will push the pipes on one side to have more room to add an extra coolant reservoir for the intercooler between the catch can and the CAI.
And I will probably fix this new tank on the same bracket now facing the front
(One fixation for both mods..)
Old 08-14-2018, 12:44 PM   #48
Fraxum
Fraxum's Avatar
Originally Posted by Deuce22 View Post
Honestly this is the only place it fits on this car!!
But that leaves no room for the SC coolant reservoir. I think I saw an up front placement somewhere.....
Old 08-14-2018, 02:56 PM   #49
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Cordes Performance has a much larger 1 gallon tank that goes up front. They also send a bracket for catch can mounting off of strut tower
https://www.facebook.com/commerce/pr...010469798&rt=6
Old 08-15-2018, 10:21 AM   #50
Biscuit.fr
Ext connections are the same?
Can we switch them from the T and intake 90deg
Both are succion ?
Or do they play different rules inside the can?
Tx Elite for the answer
Old 08-15-2018, 03:09 PM   #51
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
if your gonna do a reservoir might as well go beast mode and put something in the trunk with larger capacity and have ice capability.. if its double wall could even add dry ice as long as it vented..
Old 09-29-2022, 10:16 AM   #52
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
Drives: SIM 2SS/RS M6
Originally Posted by Elite Engineering View Post
This is our E2-X Ultra can and although it is tight, it fits. You can also mount it off the driverside strut tower mount using a combo bracket:
And what your stopping:
PCV cartridge location you replace with our billet diverter valve:
Hope this helps all. The cooler the location, the better, but these are tight engine compartments. All is the same as the LT4 Z06 except the mount location. And even on the CAI box is another some have done. Them you just drill 2 holes in the box and push bolts through to the C clamp.
What bracket is this?
"Letty" Murdered out 2013 Camaro 1LE. (Old car SIM 2010 2SS/RS)
5th_GEN_SS is offline   Reply With Quote
Old 09-30-2022, 09:57 AM   #53
Elite Engineering
Drives: 2010 Camaro
The top picture looks like our XL Bracket, the bottom picture looks like our medium L bracket.
Old 09-30-2022, 11:33 AM   #54
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Thats cool, but i think Synergy's 2 gallon fender tank with bleeder valve might be better for some, although it wont help if you were wanting to add ice.
