#43 | |
#44 |
Yep, there is offset bushing etc to allow you to degree the cam in. The factory is like 50 degrees variable anyhow. My original Txspeed cam was 20 degree limiter, and my new cam is zero to 6 due to my aftermarket pistons having huge valve pockets. stock piston it is zero. My C5R chain is heck of tight. no slop
#45 | |
![]() Drives: 17 krypton green 1le Join Date: Feb 2017
Oil pan removal
I’m trying to decide what route I want to take and this seems the best fit for me. I would try to jimmy the chain off the cam sprocket but I’d really like to go with c5r chain so I’m looking at removing the oil pan or entire engine. Also as some have said I appreciate the good info from oldman, KingLt1 and others; especially all the valve-train guidance I’ve seen lately. I want as much reliability as realistic. |
#46 |
dropping the pan added about 1.5 hours total to the job.
#47 |
![]() Drives: 2017 1SS 1LE Join Date: Jan 2018
It amazes me what you guys do in your garages. I wish I had half of that confidence, patience, and experience!
I'm tempted to pull the heads and try reassembling the valve train as a learning exercise. Probably a bad idea. Is there any benefit to upgrading parts of the valve train if staying stock cam?
2017 Camaro 1SS 1LE - Stock for now
2015 VW Golf R DSG - GIAC ECU/TCU tune |
#48 |
![]() Drives: SS 1LE Join Date: Oct 2017
#49 |
did both
#50 | |
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
#51 |
It's not that I'm against a (mild) cam, I'm just scared to attempt something that involved in my garage! Especially never having done it before. I'd love to learn, though, which is why I've thought about a valve train rework, even if it's just mostly a disassemble and reassemble to get more comfortable with how everything works together. I suppose it's mostly a question of confidence, and how to build it up enough to tackle larger projects like a cam.
#52 |
It a hobby for me, so I can see doing heads only. I would go with a Proflow intake valve if you want maximum flow (undercut head), if money is not a big issue. I got my heads ported by Pray things of beauty. The aluminum block does not like many torques / torques so I would go with stock head bolts or ARP studs but only to 105 ft -lbs. Or just buy these studs cause ARP is only thinking about a limited use race engine, not Joe Normal working on his engine as a hobby.
https://www.livernoismotorsports.com...structions.pdf
#53 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I'm 61 and have been wrenching on cars, motorcycles and boats my entire life and cannot imagine having a modded car and having to rely on others to keep it running. The reality is, there is almost always something that needs tweaking once you start modding. It's a lot more cost effective to do things yourself as well as a lot more satisfying. You will probably find that you enjoy working on your car as much or more than driving it. Look at Oldman for instance; you never see him posting about driving his car, but he's probably had his motor apart a half- dozen times trying out different combinations of parts lol!
Baby Blue
#54 |
What, I'm suppose to drive the thing
#55 |
Yes, a minimum of 500 miles between cam changes
Baby Blue
#56 | |
Are there any particular books/manuals you would recommend for learning more about GM engine building? I figure Gen V is probably too new, but are the LS series books/manuals still mostly relevant?
