#43 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
After it was determined that the fluid was the problem, only a single flush with the upgraded fluid was the procedure.... I'm wondering if flushes and TC replacements were done before the upgraded fluid was put into use....If all the triple flushes, TC replacements, then "single flushes" were done with the new and improved trans fluid, then I stand corrected. Thanks. Yeah, a re-read showed you are correct...I misunderstood the triple/single flush business... "So, what is the service procedure? Once we determined the issue was due to the quality of the friction modifier in the fluid, we developed a service procedure to flush and fill the transmission fluid 3 times, which eliminates most of the shudder concerns. This service process may not work for a vehicle with shudder that goes too long without service, in which case it will most likely require a new torque converter. Since we started using Dexron HP transmission fluid in March of 2017 both in production and for service, we believe we have basically eliminated the shudder. When used for service, it only requires a single flush and fill. Last edited by 90503; 04-26-2018 at 10:54 AM. |
#44 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
#45 |
![]() Drives: HB 2SS Join Date: Apr 2017
I'm not completely confident in the answer but I'll take it. Worst case scenario I already accepted I should just go and get the slip values tuned out instead.
#46 |
![]() Drives: 2017 2ss, m6 Join Date: Jan 2017
The answer sounds plausible to me and I could see how a fluid spec that wasn't quite good enough could lead to the hit and miss issues. Also, I've been around a few automatic transmissions in my life (not an a8) and none of them used the torque converter in any way to regulate line pressure so I'm not seeing the slippage causing low line pressure. Maybe too much time has passed me by since tech school.
#47 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
#48 |
![]() Drives: 2SS, CT-R, LC500 Join Date: Jan 2018
GM should be proactive as someone above said. If there's A date, every car built prior, should get the triple flush and TC replaced
#49 | |
I personally appreciate the backing here... although, since I fall into that category, I'm not certain how I feel about the car being torn apart without a really solid reason (concerned about collateral damage). A free single flush and filter change, sure thing... seems to makes sense. A triple flush may be overkill. No one really knows, and for me that's the issue.
#50 |
![]() Drives: 2016 SS, NFG, MRC, NPP, Auto Join Date: Dec 2015
Thanks for the clarification, Al. I had the flush done at 15,000 and then the TC replacement. However the shudder returned at 18,000 and has been increasingly evident. I will make an appt with dealer next week (I did not want to chance driving it during snow season).
What I don't understand is, if it got a new TC and the proper fluid, why would it be happening again? At this point it only seems to occur when in V4 mode (which, I guess would be light throttle). thanks, -bill |
#51 | |
![]() Drives: 16 ngm ss Join Date: Jan 2017
#52 |
DEXRON® Brand Product Descriptions
DEXRON® Automatic Transmission Fluid (ATF) Modern ATF typically contains a wide variety of chemical compounds intended to provide the required properties of a particular ATF specification. DEXRON® ATF contains the prescribed combination of additives that improve lubricating qualities for your GM Vehicle. These additives include anti-wear, rust and corrosion inhibitors, detergents, dispersants and surfactants (which protect and clean metal surfaces); viscosity modifiers, seal swell additives and agents (which extend the temperature range of the additives' application); and anti-foam additives and anti-oxidation compounds to inhibit oxidation and improve fluid stability. DEXRON® offers two varieties of ATF, Standard DEXRON®-VI and DEXRON®-HP (High Performance), used in situations where low temperature fluidity and potential fuel economy are priorities. ************************************************** ********* I found the above at GMdexron.com....http://www.gmdexron.com/overview.aspx But I could not find anything on it being for sale or available anywhere....I googled dexron hp atf, but only got info for dexron-VI for sale, but nothing for Dexron HP....just trying to find info on Dexron HP atf.....Hopefully it does exist, and dealers have been using it....just can't find it for sale anywhere....????...Maybe I'm searching wrong or something...??? |
#53 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2017
My 2016 manual says to use GM part number 19300536.
But I read on a corvette forum that that part number has been replaced with 19353429.
#54 | |
It’s Mobil 1 the dealers have it. |
#55 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Norm
'19 WRX 6M (the family sedan . . . seriously) |
#56 |
Yeah. It looks like it's pretend and extend. We do have 5 yrs 60,000 miles to get this fixed repeatedly, correct?
It makes business sense to do it this way. Such is life. |
