Old 03-20-2018, 08:24 PM   #43
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Thanks for posting. Let us know if you feel any change in the suspension after the install. I can only assume the FEA bushings use a stiffer rubber. The FE4 ride link bushings are the only ones that appear different among all 4 pairs of part numbers, for what it's worth.
In some ZL1 1LE marketing GM claims the FEA suspension uses stiffer ball joints, so that's a probability that's hidden underneath the weather boots.
Originally Posted by sadpanda View Post
If there is no difference in arm thickness then I'm going to guess there is no difference. Only possibility would be different durometer rubber bushing or briefer ball joint... But I doubt it.
As we've discussed, different part numbers ! = different parts
Let's not jump to conclusions until we can prove it.
Think about it from a suspension tuning standpoint. The FE2 comes with 245 section all-season tires, and the FEA comes with 305 & 325 wide R-compound tires. There isn't a rational reason to run the same bushings as the deflections and subsequent dynamic alignments would be significantly different between the two. As a rule of thumb, the greater the tire grip, the stiffer you need the bushings to be. Conversely it's nonsensical (and a waste of money and lack of durability) to run sphercial-bearings on narrow all-seasons as the precision movement is made moot by the large tread squirm. GM may be using the same molds on some bushings but it would be naive to assume they're the same durometer for such a huge span of performance characteristics.
Old 03-20-2018, 11:29 PM   #44
EMTNLSS
EMTNLSS's Avatar
Drives: 2016 Hyper Blue 2SS
I'll see if I notice a difference once I get my summer tires on. I replaced both front control arms with the FEA versions. I'm running 245 winter tires right now so they aren't the best for handing lol.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune
Upcoming Mods:
EMTNLSS is offline   Reply With Quote
Old 03-21-2018, 12:00 PM   #45
sadpanda
Drives: 2014 ATS 2.0T 6MT
Agreed, however... The geometry looks the same and if the part is 'sufficient' they may have spent money elsewhere. Maybe some closer inspection of the bushings (might be a small molding number hidden somewhere) and obviously a good look at the ball joint would be in order.
Heck it could have exactly the same bushing but a harder ball joint.
Kinda sucks these look like single use parts... Bushing is probably serviceable (possibly replaceable with poly/solid) but the ball joint probably not.
sadpanda is offline   Reply With Quote
Old 03-30-2018, 03:16 AM   #46
Mrfixxit7
Mrfixxit7's Avatar
Drives: FIFTY 2SS Callaway
Hey guys the rear sway bar for a convertible ZL1 (FE4) is a different part number, it is 84118919. Would there be any difference between the two or is it just different number for a coupe vs a convertible?
Mrfixxit7 is offline   Reply With Quote
Old 03-30-2018, 11:45 AM   #47
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Thanks. I checked Post #3 and I already had it in there.
ZL1 convertible internal chassis code is AL67. The AL37, aka ZL1 coupe, uses a different part number rear stabilizer bar. Exactly what's different between the two isn't yet known. My guess is they chose to tune the stiffness rates on the rear stab bars on the SS and ZL1 'verts differently for the change in vehicle weight and/or chassis torsional rigidity. My hunch is they're softer than the respective coupe bars. I don't believe there's a physical constraint to have the convertible be a different shape, as the LT 'verts don't have a different rear bar number.
Old 04-04-2018, 08:03 PM   #48
Mrfixxit7
Mrfixxit7's Avatar
I recently got some ZL1 parts and they had slightly different numbers than what you had on some parts (I might have missed something).
The rear MRC dampers part number was 84219920
The rear knuckles were 84382226 & 84382227
They were off a 2017 ZL1.
Old 04-05-2018, 09:04 AM   #49
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
I recently got some ZL1 partsand they had slightly different numbers than what you had on some parts (I might have missed something).
That damper number may very well superscede 23281657, as it's one digit less than the current right side MRC rear damper (84219921).
Those other part numbers aren't knuckles, but new part numbers for the rear lower control arms, you can see the "replaced by" here at GMPartsGiant.
Thanks for the updates.
Old 04-07-2018, 05:58 AM   #50
Soleil
Soleil's Avatar
Originally Posted by Ryephile View Post
If you have an FE2 car, "R0H" is the code for the factory 18" wheels and tires, and "R29" is the code for 20" wheels and all-season tires.
Rear Springs for Non-MRC. I know this is really hard to decipher, but it depends on the exact configuration of your VIN. Things like "xCA" means it can be either 8CA or 9CA, the part numbers are the same.
AJ37, AG, AH, AJ, AK67 (xCA) = AAZ5 = 23341852
AG, AH37 (xGA) = AAZ6 = 23341853
AG, AH37 (xHA) = AAZ7 = 23341854
AG, AH37 (xJA) = AAZ8 = 23341855
AJ, AK, AG, AH37 (xAA) = AA0D = 23341860
AG, AH, AJ, AK37 (xBB) = AA1N = 84010830
AG, AH37 (xDX) = AA4R = 84153696
I don’t know if this is a typo or it is the same spring.
AG, AH, AJ, AK37 (xBB) = AA1N = 84010830 it is for MRC. I just changed mine to lowering springs.
Soleil
Old 04-07-2018, 07:43 AM   #51
Mrfixxit7
Mrfixxit7's Avatar
A fun one. The MRC computer that resides under the trunk floor is part number 84214461. This at least its second part number.
Does anyone know if the MRC computer "tune" is the same for all FE4s both coupes and convertibles or is there a FE4 coupe tune and a FE4 convertible tune?
Old 04-13-2018, 02:08 PM   #52
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Interesting, MrFixxit just posted in the classifieds that same part number as a non-MRC FE3, so perhaps it's used on both dampers. It wouldn't surprise me in the least.
Old 04-13-2018, 04:52 PM   #53
Soleil
Soleil's Avatar
I thought the FE3 is always with MRC
Soleil
Old 04-13-2018, 08:51 PM   #54
Mrfixxit7
Mrfixxit7's Avatar
I went off the list, I am not sure what car the springs from.
Old 04-15-2018, 06:21 PM   #55
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
No, it's an option on FE3.
FE4, however, is always MRC.
Old 04-15-2018, 08:09 PM   #56
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
cool post... this is also the rear V6 1LE spring.
Springs:
V6 1LE Springs
Front: 84186922
Rear: 84010830
V6 1LE Shocks:
23382416 Shock Absorber CAMARO; W/O VARIABLE DAMPING; W/SPORT SUSPENSION; LEFT
84084730 Shock Absorber CAMARO; W/O VARIABLE DAMPING; W/SPORT SUSPENSION; RIGHT
http://www.camaro6.com/forums/showpo...0&postcount=21
cool to know its cross-used with MRC on some models.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
