Old 03-23-2018, 07:51 AM   #43
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by JFM-jr View Post
I watched the Facebook live feed today that you guys did on the 1st of the Dyno hits with this kit it really is a clean kit and the initial pump gas numbers are awesome. I am super interested on what that fuel setup supports on E85.
Thanks for following, the Preliminary numbers are amazing, 611 RWTQ and 595 RWHP.
After the Live Feed we installed different wastegate springs shooting for 10 psi and ended up with 11 psi.
It made 708 RWTQ, and 675 RWHP but it had too much knock retard due to the stock Cats, even with only 9 degrees of timing so we are installing Off road pipes for more testing.
The fuel system is limited by the stock cam right now, I expect to find the limits of the LT4 fuel system parts pretty easy with this turbo system as we are not even scratching the surface of what this system is capable of.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 03-23-2018, 08:08 AM   #44
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Ted.
That situation seems familiar!. Can't wait to see the results of the offroad pipes, etc.
Dysan911 is offline   Reply With Quote
Old 03-23-2018, 08:08 AM   #45
solobaric
solobaric's Avatar
Drives: 2002 Camaro SS
Wow. Pretty incredible.
2017 1SS Hyper Blue M6
2001 Ford Lightning
solobaric is offline   Reply With Quote
Old 03-23-2018, 08:23 AM   #46
Calubi
Drives: 2017 1SS 1LE
Very nice!
Any impressions of how it drives on the road?
2017 Camaro 1SS 1LE - Stock for now
2015 VW Golf R DSG - GIAC ECU/TCU tune
Calubi is offline   Reply With Quote
Old 03-23-2018, 08:28 AM   #47
JFM-jr
JFM-jr's Avatar
Ted.
I get a notification and honestly i watch just about every live feed you guys do im addicted lol. That was actually me asking about the fueling during the feed. Seems the stock cams fuel lobe will be the limiter , its a bit smaller than the stock LT4s fuel lobe as it is (5.7mm vs 6mm) not sure how much less that drives the pump. Seems the low side ZL1 pump with the JMS unit is plenty.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 03-23-2018, 08:40 AM   #48
JANNETTYRACING
Originally Posted by Calubi View Post
Very nice!
Like factory but much faster, and this is an 8 speed auto.
Old 03-23-2018, 08:40 AM   #49
JANNETTYRACING
Thanks guys.
Old 03-23-2018, 08:48 AM   #50
JANNETTYRACING
Thank you for following us, we appreciate the support.
Ted.
Old 03-23-2018, 08:49 PM   #51
steelheadrob
Tactical Garage
steelheadrob's Avatar
Impressive as always Ted.
steelheadrob is offline   Reply With Quote
Old 03-24-2018, 07:39 AM   #52
JANNETTYRACING
Little update from yesterday, still more testing to do.
https://www.facebook.com/jannettyrac...5678525999091/
After this video we put in E-50 and attempted a pull it made 701 RWTQ but ran out of fuel after 4500 rpm so we aborted the run.
Will be testing less boost on E-50 on monday.
Old 03-24-2018, 07:53 AM   #53
L78toLT1
L78toLT1's Avatar
Ted.
very elegantly engineered kit and impressive numbers! Not to hijack this thread but, as I am waiting on my Maggie kit to arrive - should be any day now! I am curious about the effect of the cats on knock retard. I have kooks LT's with high flow cats. Would I benefit from off road pipes? I'm out in the sticks in north GA where we do not have to deal with emissions testing.
thanks,
Jim
Baby Blue
Old 03-24-2018, 08:02 AM   #54
JANNETTYRACING
thanks,
Jim
I don't see the aftermarket High flows being a problem unless or until they fail.
Ted.
Old 03-24-2018, 08:39 AM   #55
JFM-jr
JFM-jr's Avatar
Interesting im taking notes on this portion imparticular
Rotofab
11.0@124.9
Old 03-24-2018, 09:27 AM   #56
JANNETTYRACING
A cam with a 32% lobe would be a game changer for sure.
Ted.
