Old 03-02-2018, 04:35 AM   #43
cwebster
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6
Originally Posted by Stephen12ZL1 View Post
the only thing I feel strongly about is no one is sure which way is correct.
Okay good. If this is true then click over to the Ask Al thread and leave your thoughts on the topic one way or the other.
So as not to sidetrack this discussion any further, I will deal with your misunderstanding and ridicule of my warnings via private message when I have some time later today or tomorrow.
--Cal
cwebster is offline   Reply With Quote
Old 03-02-2018, 02:22 PM   #44
cwebster
Cal
Originally Posted by hawk02 View Post
Yes, I got the bolts from That GM Parts Guy.
When the dealer confirmed the part #, I had the same thought about the online parts catalogs just not being up to date. What's really strange is the online diagram assigns the bolt a number but does not include that number in the list of parts that can be ordered.
Since the bolt was being reused, the alignment tech did not torque it to angle.
I ordered a pair of new control arm bolt washers. Should be here on Friday. I'll let everyone know if the new washers fit.
Had my new alignment hardware replaced this morning and the alignment re-set. The rear alignment hardware came as a kit, including bolts, eccentric washers, and lock-nuts. I got there a little early so I could photograph the labels on the new hardware for future reference.
Everything went smoothly and the new alignment specs match the previous settings exactly. The mechanic said he was surprised at how easy it was. He expected TTA to throw off the alignment after he set it all up but all went like clockwork.
After I returned home I went ahead and recorded all the information from the labels. Then I visited "That GM Parts Guy" to see if they had them all. First I used their vehicle selector to specify [2017 Chevrolet Camaro ZL1]. Then I copied all 6 GM part numbers into the search bar at once. All of them came up on the page. I opened the product page for each item, looking for any warnings or notices about incompatibility. I saw none. Every page said "This part fits your 2017 Chevrolet Camaro". As expected, a note accompanied both bolts stating "Part Is Not Reusable, Replace Only."
Below is a list of the hardware with all the pertinent related information. I've included the GM price I paid at the dealer and the listed (discount) price shown on the TGMPG site. You could apparently save about $25 buying from there but then you'd have to track the order, check it when it arrives, and re-order if something doesn't match. It may be easier to just have the dealer do everything.
So why didn't your existing eccentric washers fit on the new bolts? The service rep agreed that either (1) original parts came from a different supplier with slightly different specs or (2) the online catalog could be off. I'm thinking (1). Anyway, we know for sure that the kit ordered through the dealer will work. If someone else here orders bolts and washers from TGMPG and they work, please update the thread so everyone is informed.
Move the slider over to see the GM and TGMPG pricing
Code:
        Package         GM      GM      TGMPG   TGMPG
Item Name                               Qty     GM PN           Description     Unit $  Ext $   Unit $  Ext $
Inner Link Rod Bolt (TTY) - Toe
(w/eccentric washer)                    2       11611276        [bolt 5.416]     3.65     7.30   2.42    4.84
Lower Control Arm Bolt (TTY) - Camber
(w/eccentric washer)                    2       11547215        [bolt 5.383]     15.95   31.90  10.54   21.08
Inner Link Rod Washer (eccentric)       2       11611277        [washer 5.416]    3.79    7.58   2.51    5.02
Lower Control Arm washer (eccentric)    2       11547262        [washer 5.383]    7.12   14.24   4.71    9.42
FT (lower) Control Arm Nut (locking)    2       11516382        [nut 8.917]       1.63    3.26   1.08    1.16
Stabilizer (inner) Link Nut (locking)   2       11516078        [nut 8.917]       4.39    8.78   2.90    5.80
Total:        $73.06         $48.32
TGMPG Savings: $25.74
I can upload the label photos if anyone wants to see them.
--Cal
Old 03-02-2018, 03:00 PM   #45
hawk02
Coupe Newbie
hawk02's Avatar
Code:
--Cal
I received the camber bolt washers this afternoon and can confirm they fit over the bolt. Why the original washers didn't fit is anyone's guess.
I'm going to order the nuts just to be on the safe side.
To avoid the problem I had, one should order or make sure the dealer orders the lower control arm bolt (11547215), eccentric washer (11547262) and nut (11516382).
For the rear toe, just the inner link bolt (11611276) is all that's needed. The original eccentric washer and bolt will fit fine.
Old 03-03-2018, 06:37 AM   #46
cwebster
Cal
Good info! Thanks!
Old 08-17-2018, 06:27 AM   #47
Akura
Akura's Avatar
Drives: ´18 ZL1 A10 Red Hot 😍
Can anyone confirm these PN fits 2018 model?
Thank you.
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
Akura is offline   Reply With Quote
Old 08-17-2018, 08:05 AM   #48
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
https://www.camaro6.com/forums/showthread.php?t=502324
thescreensavers is offline   Reply With Quote
