#43 |
Congratulations on your new Camaro
![]() No need to kill the engine and wait for it to cool down at all, just vary your speed, don't drive at a constant 65-70-75 mph in the same gear for hours. Enjoy a few little half throttle, 3.5-4k rpm bursts from 30 to 70 mph in the right lane, shift down and back up periodically etc. The idea is that you don't want the engine running at the same rpm under the same low load for extended periods during the break-in. That said, the LT4 isn't made of candy, don't worry, you won't break it with your driving. Now as to whether or not this is a proper break-in procedure, that is a whole deep rabbit hole that I don't want to descend into. At the end of the day, this is the official recommendation from the manufacturer, and you will find plenty of information even here on this board if you're interested in more details.
#44 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
Vary your rpms.... If you have the 10 speed its eassy. 6 Speed just vary between 5th and 6th occasionally. Forget cool down not needed.
2012 Yukon XL Denali w/ 6.2 AWD |
#45 |
![]() Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
#46 |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I test drove (very spirited style) my car for an entire weekend and about 200 miles. I then returned the car, left a deposit on the car and moved from TN to Denver. After I finished the move, I flew back to TN, picked up the car and drove it 1400 miles to Denver. I changed the fluids (oil, filter and rear diff) after arriving in Denver.
#47 |
![]() Drives: ZL1 Convertible; 6-speed Join Date: Sep 2021
I see a lot of diff oil changes being mentioned but does that also apply to Verts without eLSD?
#48 |
Any thoughts on when I should do the first diff fluid change on a vert ZL1?
#49 |
Thank you Al Oppenheiser!
For street use, the manual says every 45k miles.
You'll need 2qts of P/N# 88862624 Dexron 75W90 LS Gear oil incl. limited slip friction modifier. Get a hand pump. Last edited by Gunkk; 07-23-2022 at 11:16 AM. |
#50 |
#51 |
He's just saying that is what the owner's manual calls for. I had the dealership change mine at 1500 miles.
#52 |
#53 | |
#54 | |
Maybe 100 miles? Lol
#55 |
![]() Drives: 2022 ZL1 Join Date: Aug 2013
#56 |
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
I wonder how many here that followed break-in procedures and warm vehicle prior to WOT had oil pump failures?
