04-16-2018, 11:38 AM | #43 | |
Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
The ECU closing the throttle to 20% (as shown in multiple data logs) is NOT a mechanical issue. It is a software issue. The torque management table is not editable on HP tuner's platform. They've promised to rectify and have since gone dark. You can't agree to disagree with fact (unless you're a politician then that is your job) Fact: Throttle closed to 20% on launch due to a torque management table which cannot be adjusted. Opinion: You're bogging because of the car's mechanical setup.
//2016 1SS M6 D1SC Upgraded IC 4.25 Pulley//
// Alky Control Meth Kit running 100% methanol // (purchased from JDP, installed by True Bliss Customs, tuned by NewEraPerformance in Augora Hills) // 3M/Gotch Design Sponsored Gloss Deep Space Colorshift Wrap // |
04-16-2018, 03:40 PM | #44 |
Okay I still believe in the tooth fairy and the bog issue. It is real just like the $$ under your pillow. Fact. Even GM admits it.
So GM says clutch just right or go home slow. My question is which tuner has the 60's to show they fixed it? GM is pretty clever and knows we can break these expensive diffs it we get things just right to apply the maximum amount of torque in this heavy car. I think the fix is just like a solid Yeti sighting...... Some have reported it but where is UTube and the genetic evidence?
04-16-2018, 04:57 PM | #45 |
Dyno Show Queen LOL
I have a 9.17 pulley, headers, TMamo TB, and CAI elite intake. If I hold the traction button for the 7 to 10 seconds and see both lights pop on.. I can Rev at 1k, 2k, 3k, anything else is silly dump the clutch this thing will light the tires up no bogging.
If I use track mode and any of the settings wet, dry, race, ect and do the same it will bog, spit, and sputter. Especially on dry cement that you can get traction on.. on aspault not as bad, on wet asphalt it just spins but no sputter or bag.. Is this the issue everyone is having.. My friends 2018 blue 1le.. you may have seen it on Phastek last week for the borla xpipe or today or tomorrow for the 1st 6 gen stainless brake lines. He was at MSR which is asphalt was able to use launch control no problem then I showed him my zero to 60 of 3.9 for a stick he said he could beat it .. I said what about bog.."mine don't bog" he gets in front of my shop on some good new laid concrete down the block.. my other friend and I heard from down the block bogoing of the line w launch control. He was,like it didn't do it yesterday! I was like looks like 18s still have it and besides your cheating I didn't use launch control!
04-16-2018, 07:46 PM | #46 | |
Drives: 2018 ZL1 M6 Join Date: Dec 2017
It all boils down to this:
04-17-2018, 04:36 PM | #47 | |
I think this is exactly what you see in modded manual drag 6gens. I know NFGGirl's videos all look the same. Car falls completely flat on its face and then almost wheelies shortly after like the computer was like "ugh, alright here is all your torque back" I believe it was Pray or one of the other guys that actually datalogged this at the track and found that the throttle itself is being closed by the computer for a bit and then swung back open. HP tuners blames the table, so it could very well be up to HP tuners to give us a proper verdict; their forum has a topic up with a response saying "we will fix soon" which is probably over a year old now.
04-18-2018, 06:42 AM | #48 | |
04-18-2018, 10:22 AM | #49 | |
04-19-2018, 03:11 PM | #50 | |
04-20-2018, 07:34 AM | #51 | |
But still no bog fix with a tune so far. Been there tried that.
04-20-2018, 09:06 AM | #52 |
Drives: 18'-1LE Join Date: Jul 2017
Sucks for Travis, he has plenty of time invested in this cluster f()ck...
07-17-2018, 03:18 PM | #53 |
Drives: A few of each Join Date: Dec 2017
Bump. Just went from an A10 ZL1 to a ZL1 1LE. The car is great, but this bog/self-rev/sputter/lag down to 400rpm/unpredictable garbage while just taking off from a stop is infuriating. The only fix I've found is to completely ride the clutch out to 15mph or so before it's completely engaged. Then it behaves and will roll slower in first. Getting rolling, though, is way more complicated than it should be. I've owned at least 10 manual-transmission performance cars. None exhibited this behavior or even came close.
'18 MBM ZL1 1LE
07-17-2018, 03:21 PM | #54 | |
Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
07-17-2018, 03:50 PM | #55 |
Who Needs to KNOW?
It makes it really tough to get off the line with any kind of urgency in track mode (regardless of mode)... unless wet and then it just beautifully spins the tires!
You're fully expecting to get pegged into seat and instead you are jerked forward - sucks when you have helmet on your head and you turn into bobble toy. Pretty sure I have few videos of it in action.
ing for grip.
07-17-2018, 04:11 PM | #56 | |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
