Old 01-30-2018, 06:48 PM   #43
brettman
Drives: 2016 Camaro SS
Originally Posted by Joe's_cool_1le View Post
Needs a bore of .005 because off scratches
What is the bottom line $$$$, for the repair? If I may ask. SO, If I blow mine up
I have an idea...l Or Pm me, or don't me...lol.
brettman is offline   Reply With Quote
Old 01-30-2018, 08:02 PM   #44
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
Lol. I should know tomorrow.
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 01-30-2018, 10:01 PM   #45
jeffm4688
Drives: 2015 Camaro 2SS 1LE
I had the same problem in June with the front seal blowing and I let my car sit until November. We had thought it was rings and did eventually confirm ring lands on destroyed two cylinders. I just put my engine back in last week, working slowly on putting everything else back together. :bonk
jeffm4688 is offline   Reply With Quote
Old 01-30-2018, 10:16 PM   #46
oldman
Drives: SS 6 speed of course
Bout how much hp and boost we’re u making?
Old 01-30-2018, 11:48 PM   #47
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Pretty sure he was right at 11psi and 600whp with stock fuel system. 1LE has ZL1 in-tank.
http://www.camaro6.com/forums/showthread.php?t=488249
Old 01-31-2018, 09:36 AM   #48
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Houston we have a problem
That's exactly what happened to mine when the front seal blew out. Pistons broken on the ringland. Mine was about 650 whp on 11 pounds of turbo boost. I ordered a complete new forged motor from LME before the stock engine was out, not a cheap fix but should not have another engine problem.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 01-31-2018, 10:21 AM   #49
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Did you see the catch can I installed? Just needed one fitting and replace (reuse) an OEM fitting to get a better routing.
Hey Brett,
Finally had a chance to go through your entire build thread. Took me every bit of 2 hours. good write ups and laughs.
However, there were only two posts regarding your catch can. no real identifiable routing of the hoses as to there end place. I think that's my real question.
We can talk off line if need be. I used to have a mishimoto prior to my supercharger install, but now there are others starting to gain traction such has mighty mouse and Elite (sp) I just need to know the routing of them.
Guess I'm confused as to the atmosphere vent and the actual catch can portion of it. And maybe I need to create another thread and not thread jack yours. apologize if I did.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 01-31-2018, 11:03 AM   #50
brettman
Originally Posted by oneredry View Post
Hey Brett,
Glad I could give you a laugh or two. I think most of the catch can stuff is on another thread. Pm me W/ Email, I have (4) pics that will at least help with your Elderblock.
(same fill tank location, and intake manifold fitting)
Now, of course, that wouldn't help Joe. A block of wood under the throttle pedal would probably be better...lol. But with all that is going on, I'm scared, REALLY.
Some run high HP (stock pistons, fuel system) no problem. Others lower HP and fail. BAD TUNES??? lean?? Seem a poll should be started for data.
Sorry Joe, JACKED your thread again...LOL
Old 01-31-2018, 05:17 PM   #51
Chevy71
Drives: 2016 2SS
on the same yet, slightly different subject. If someone makes a kit that has what mishimoto does to boosted engines, I'd buy one. since the ports have changed on the intake, I'm sorta lost as to how it would be routed. the the DIY kits seem decent in my opinion, I feel that there should be a vent/catch can type of set up.
There are a lot of kits far better than Mishimoto out there.
Chevy71 is offline   Reply With Quote
Old 01-31-2018, 05:23 PM   #52
Chevy71
Drives: 2016 2SS
I watch the forum with C7 vettes because they seem to be ahead of us. When I seen the trend there and Vengeance had a sale, I just bought forged pistons and swapped them before bad news struck me. The good news is, I have 8 easy life, lightly used stock pistons that I can sell to a guy in a pinch! Haha. Leannis typically an issue, but these pistons seem to be weak. If it was lean we would see issues on the crown, not the ring lands.... don’t you agree?
Old 01-31-2018, 05:32 PM   #53
brettman
Buddy, I agree with you (another diesel guy) Just don't understand the rime or reason...lol. Side note: good to see you...Back????
Old 01-31-2018, 09:32 PM   #54
KingLT1
KingLT1's Avatar
Lean can still break ring lands and not damage the piston surface. I can't explain it but I have seen it before. Actually I experienced it in gen 4 LT1 that I installed a Procharger on. I had Bryan Herter from PCM4less(popular tuner back in the early 2k) send me a tune which ended up being the wrong tune( for a NA setup). Popped a head gasket and broke #8 ring land. Piston was unscathed. Car still made 440whp on 7psi blowing the oil dip stick out of the tube.
Old 02-01-2018, 12:42 PM   #55
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
We have posted in several threads, but for ANY boosted application, we really recommend our E2-X "Ultra" Catch Can system. It makes it virtually impossible to have crankcase pressure. We pull evacuation suction at all times on the crankcase, and our -8 or -10 CSS will never allow pressure to build even if a ring got pinched.
Elite Engineering is offline   Reply With Quote
Old 02-01-2018, 12:50 PM   #56
oneredry
HYPER SS
oneredry's Avatar
If you make a kit for my application (Maggie) I'll buy from you today. I don't want to piece it together find this part, to match that part and figure out what line goes where. Do you have this?
Ordered: 1/15/2016
Delivered 03/23/16
