Old 06-19-2021, 08:28 AM   #43
Envious_Ivy1LE
Envious_Ivy1LE's Avatar
Drives: Krypton Green V6 1LE
Originally Posted by JeromeS13 View Post
FYI, PTC 97419 studs work too. I ordered them from Rock Auto $1.10 each (much cheaper than Dorman or ARP). They're ~ 15mm longer overall, but have ~24mm more thread engagement, due to being threaded longer.
https://www.rockauto.com/en/moreinfo...841348&jsn=254
does anyone know if these will slot in without removing the caliper and rotor? I'm trying to do this right now and can't seem to find a position to get it to come through. it might be slightly too long
Envious_Ivy1LE is offline   Reply With Quote
Old 06-21-2021, 10:06 AM   #44
Envious_Ivy1LE
to answer my own question for anyone using the PTC 97419, they won't slot in without removing the caliper and rotor, not without modification. Looks like the ARP studs have a flat section in OPs guide and these don't. if you were to make a flat section on the head similar to the ARP then it might be able to slot in and not get caught
Old 07-03-2021, 07:05 PM   #45
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Nope! You can get 1/2" longer studs in but not 1". It's quick and easy to take the caliper and rotor off, about the same amount of work as grinding the studs anyways.
I usually spring for ARP, especially since I'll be using 26mm spacers but they are out of stock. I used these Dorman studs, worked fine and costs $25. PTC are prolly fine and even cheaper. Dorman are ~5mm longer and I recognize the brand.
https://smile.amazon.com/dp/B0033YJC...roduct_details
Old 07-29-2021, 03:44 PM   #46
CRBWS6
CRBWS6's Avatar
Drives: 18 1SS 1LE SCCA FS, 99 WS-6, E46 M3
I agree with longer studs for 5mm spacers (I tested some and only got about 6.5 turns on OEM SLE wheels).
But is it OK to use stock studs w/3mm spacers? These are required for inside front clearance with some MRR wheels. I am estimating it would get just under 8 turns which I have read on here is sufficient.
CRBWS6 is offline   Reply With Quote
Old 07-29-2021, 04:23 PM   #47
DaveC113
DaveC113's Avatar
But is it OK to use stock studs w/3mm spacers (required for inside front clearance with some MRR wheels)? I am estimating there it would get just under 8 turns which I have read on here is sufficient.
Sounds about right, I think you could use 5mm but it's borderline, 3mm should be ok.
Old 07-29-2021, 06:11 PM   #48
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
There's different schools of thought on minimum thread engagement. One is you want the thread engagement to be equal to the diameter of the bolt. So for our studs which are 14 x 1.5mm you would need 9 turns minimum. I can't remember what stock was when I checked before I changed studs.
14 \ 1.5 = 9.3
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
Old 07-29-2021, 06:34 PM   #49
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
14 \ 1.5 = 9.3
Stock wheels of all flavors at stock torque ends up being 14-15mm depending on tolerance stack. As you and others have seen, be sure to check aftermarket wheels. My Apex EC7's and SM10's both lost at least 2mm w/o a spacer.
RUQWIKR is offline   Reply With Quote
Old 07-31-2021, 06:34 AM   #50
carguy55
carguy55's Avatar
Thanks to your tip about minimum thread engagement I checked what it was on the rear studs with my Apex wheels and changed the rears to longer studs
Old 09-04-2021, 06:02 PM   #51
CRBWS6
CRBWS6's Avatar
To clarify - do the Dorman 610-530 (78mm Length) install w/o removing the brakes?
Old 09-09-2021, 01:38 PM   #52
infinitereality
Limitless Imagination
infinitereality's Avatar
Drives: 2018 ZL1 & 2022 Hayabusa
I was a little concerned with doing the rears, but watching the video it doesn't look too bad with pneumatic tools.
Now to go measure the ZL1 stud OD to see if they'll fit inside my SLC wheel holes.
The SLC uses M12x1.5 studs, but the opening on the wheel is larger than 14mm so it's feasible.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
- Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED
- RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook
- Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels
- +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc...
infinitereality is offline   Reply With Quote
Old 09-29-2021, 10:03 PM   #53
infinitereality
FYI the ARP 1/2" longer studs are still out of stock everywhere. Found 2 sets that were claimed to be in stock, but after a week waiting, get an email saying won't ship till December. Was worth a shot.
I am planning to run a max of 10mm spacer so expecting, with either PTC or Dorman, will likely have to cut some off since not running open end lugs. Like DaveC, I recognize Dorman brand so going with them. Also the Dorman have a tapered edge so should be installation a tad bit easier.
Old 09-29-2021, 10:50 PM   #54
Staves
Drives: women crazy
Wow, awesome DIY write up. 👍👍👍
‘19 1SS A10, Borla S-type Non-NPP-SOLD
Staves is offline   Reply With Quote
Old 10-04-2021, 09:12 AM   #55
CRBWS6
CRBWS6's Avatar
Placed an order at Jegs a month ago and website currently says the arp +1/2” will ship mid-October, but that date has changed a few times.
With a 10mm spacer, my measurements indicate that leaves about 1.5mm of exposed hub flange. Will your spacers have their own flange?
Old 10-04-2021, 09:19 AM   #56
infinitereality
If I'm understanding correctly, yes they will be hubcentric to hub and the wheel and should have the flange to fit inside the wheel.
