#43 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#44 |
Right but it's cheaper then a cam swap by far. 1500.00 for a LPE pump that will support 670-680 whp on E85 or what 4k? for a cam swap and LT4 pump so you can make 700-720whp on E85.
#45 | |
You still have to watch low side pressure, high side pressure and injection pulse time. Some people are willing to push these Items further than they should or I would for a dyno number, When you log on the street is a game changer for the above Items. Ted.
#46 |
Bump for the new guys.
#47 |
![]() Drives: 2016 Camaro 2SS Join Date: Sep 2016
Can anyone confirm that someone has safely/successfully tuned a car on e85 using the LPE big bore pump instead of the LT4 hpfp??? I am currently running LT4 injectors, hpfp and DSX aux pump. It would be nice not to have to mix e85 and 87 every time I fill up. Not to mention the savings on doing a cam install as previously mentioned.
#48 |
Yes ADM performance did...they made 680whp on a stock 1LE with LT4 injectors and LPE big bore using a LT4 blower. They gained 60whp of fuel headroom over the LT4 HPFP.
#49 | |
Note, you can not run a 32% lobe with the big bore pump. Ted.
#50 |
Ligenfelter site says their pump can take their 7.5mm lobe
#51 |
I don't know what the equates to in %
Maybe someone gave the the wrong info sorry if it was a mistake.
#52 |
LPE updated the pump to support a bigger fuel lobe.
#53 |
#54 |
Did you by chance ever get a chance to test other pullies or combinations?
Also do you use 5th or 6th gear when making a pull? How much power difference have you seen between using 5th instead of 6th?
#55 | |
Autos are 6th gear on the 8 speed, and 7th on the 10 speed. Ted.
#56 | |
I figured you probably ran out of fuel. We found the limits of the LPE DI pump on E80 @ 8psi. Hard to compare power because 5th gear was used. I imagine dropping back to E60 would free up quite a bit of headroom.
