Old 02-09-2020, 01:03 PM   #43
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
After 4 alignments and a lot of track use I'm finally going to replace the bolts. For sure they are a lot cheaper online
Old 02-23-2020, 12:17 PM   #44
Techdude99
Techdude99's Avatar
Drives: 2019 Chevy Camaro ZL1 1LE
I just purchased the rear camber and toe bolts online at gmpartsdirect. 12 bolts will cover several alignments and were $118.50 shipped.
I'll be supplying them to the local Chevy dealer or to whoever does future alignments.
A lot cheaper than buying them locally, but still freaking expensive for bolts.
Techdude99 is offline   Reply With Quote
Old 04-23-2020, 03:25 AM   #45
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
i found that ever TTY bolt on this car measured the same after being properly torqued as the new GM bolts using a starrett micrometer.
Old 05-04-2020, 01:43 PM   #46
cdb95z28
cdb95z28's Avatar
Excellent.
If the bolt did not (permanently) stretch with the proper tightening spec, then it did not yield and there is no degradation to the bolt. It can be reused.
"KEEP THE FAITH"-Fbodfather
Old 05-07-2020, 07:55 PM   #47
m3bs
m3bs's Avatar
Drives: '19 ZLE, S54 E36M3
I just finished doing track alignment on my ZLE. Based on Jimmy’18’s post above, I was very careful breaking loose the front strut bolts. I was afraid I was going to snap my breaker bar, but finally got them loose and got it done without doing any damage. I used new bolts in the rear and tightened per spec. It took WAY more torque to achieve the specified angle than I would have ever put on a bolt that size normally, so I’m not surprised if most shops don’t get them tight enough. We will see how well it holds.
m3bs is offline   Reply With Quote
Old 05-16-2020, 02:15 PM   #48
chaospiece
Drives: 2018 SS, 2016 GT
So only 2 bolts in the rear are replaced correct? My alignment guy caught this, I didn't even know but he said I need 3 bolts on one side, 2 for camber and 1 for toe.
So I'm confused.
chaospiece is offline   Reply With Quote
Old 05-16-2020, 07:02 PM   #49
Techdude99
Techdude99's Avatar
Two bolts per side on rear. Nuts can be reused.
Old 05-16-2020, 09:17 PM   #50
chaospiece
Thank you!
Old 05-24-2020, 02:17 PM   #51
Coded4SS
Drives: 23 Zl1
So after much research on this I purchased new bolts. Brought it to my alignment shop told the guy. He was friends with a GM exec and called.him.because I wasn't really sure we had to replace them. Long story short they started saying to change these bolts after "something happened" they can't talk about but their lawyers made them put it in there. Use them a few times then change them will be fine. Don't have to take it from me. But that's what went down and I was there for all of it.
Coded4SS is offline   Reply With Quote
Old 07-12-2020, 12:27 AM   #52
zain
zain's Avatar
Drives: ZL1
Just to confirm before ordering:
two of : https://www.gmpartsdirect.com/oem-pa...-bolt-11611276
two of : https://www.gmpartsdirect.com/oem-pa...-bolt-11547215
are those the correct parts for a ZL1 2018?
zain is offline   Reply With Quote
Old 07-12-2020, 07:35 AM   #53
m3bs
m3bs's Avatar
Correct.
Old 07-12-2020, 07:37 AM   #54
zain
zain's Avatar
Drives: ZL1
Originally Posted by m3bs View Post
Correct.
Thanks!
Old 08-04-2020, 09:58 PM   #55
m3bs
m3bs's Avatar
I did alignment before my first track day in the ZLE, and rechecked it afterwards and found no change. New bolts, tightened to torque + angle specs. Not much curb hopping at Roebling Road, though. Checked again after two days at Road Atlanta, and found the LR toe had shifted slightly, and the RR toe had shifted to over half a degree of toe-out. Now I need more bolts... I was hoping that the issues most people were having was the result of improperly tightened bolts, but I’m convinced now.
Old 08-14-2020, 12:12 AM   #56
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
Excellent thread!
Tim M is offline   Reply With Quote
