07-20-2017, 05:49 PM | #43 |
Drives: ZL1 1LE Join Date: Oct 2016
Check out the Moreno Motorsports camber plates, that's exactly what you are referring to. As far as poke on a ZL1, if you take a look at pictures of the ZL1 1LE they just ever so slightly poke out (not a lot at all), so add a few mils for the spacer and you'll have an idea how much it will poke on a ZL1.
07-20-2017, 08:29 PM | #44 |
Instagram: @SSAVAGEVERT
Drives: 2016 SS M6 Vert Join Date: Jan 2016
ZL1 1LE wheels offset confirmation (from a new owner or dealer)
Ours just was delivered! Follow @atlmuscle on Instagram for more pictures and videos
2.9L Whipple | Compstar Rods, Diamond Pistons & GPI Cam | Mantic Triple Disc | Corsa Performance Exhaust | DSX Aux Pump | LT4 Fuel System | BMR Lowering Springs | ZL1 OEM Conversion | 360 Customs Built | And More!
Click & Follow My Build Last edited by ChadFarr; 07-20-2017 at 09:28 PM. |
07-20-2017, 09:28 PM | #45 |
Uhmm what?
07-20-2017, 09:32 PM | #46 |
Drives: 2020 ZL1 1LE Join Date: Jun 2017
Thanks for sharing that picture. That's likely my white one headed to Hendrick.
07-20-2017, 09:56 PM | #47 | |
Drives: 2020 ZL1 1LE M6; previous 2018 ZL1 Join Date: Jun 2017
07-21-2017, 01:11 AM | #48 | |
It was headed to Montana...
Click & Follow My Build |
07-25-2017, 10:44 AM | #49 |
07-27-2017, 07:17 AM | #50 |
Drives: 1LEs Join Date: May 2009
Have received one front and two rear A1Z wheels in. Doesn't really matter since the G3R's are not in yet either.
On my own shipping scale, accuracy seems decent but is unknown, the front weighs 26.8# and rear 27.1#. Similar to my SS 1LE wheels as far as fronts not much lighter than rears since it is just the thin 1" wider barrel in the rear for the most part. These are about 3# each lighter than the SS 1LE wheels. Also, on my same scale, the G3's weigh 31.8# for the 305 and 29.5# for the 285/30/20. I will weigh the 305 & 325/30/19 G3R's when they come in. Last edited by RUQWIKR; 07-27-2017 at 08:30 AM. |
