#43 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
You dont need a tune for porting the throttle body. The throttle body opening where the blade closes isn't shaved away, so essentially you just remove any bumps or excess material leading up to and away from the blade where it comes into close contact with the TB.
It really shouldn't make much of an impact since the blade isn't exchanged for a bigger one and the TB dimensions aren't changed for that area that the blade works with. Get a tune, or live with it. Any method of playing with it (including peddle devices) will void portions of your warranty. To me, if your car has been fine for months then it's probably gonna be fine as far as what the warranty covers anyway so void away. I have the trifecta tune on my v6. It effectively removed nearly all instances of the throttle lag. The only time i have an an issue is exactly as described in that service bulletin, where you have not yet given the transmission time to downshift to 1 before getting on the gas, leaving you likely in 3rd still and causing a delay in expected acceleration. That's really hard to do anything about unless you move to manual mode but then your rpms are high and braking is compromised. give and take there. The trans is just a bit slow on the gear change. |
#44 |
![]() ![]() ![]() ![]() ![]() Drives: 2012 1SS IOM Join Date: Oct 2009
No I didn't... I did a CAI with the ported throttle body at the same time and didn't get a CEL from either. I got the tune about a month later to remove torque management and get a few more gains.
2012 Camaro SS IOM "TigreSS" Borla "S" Catback C.A.I. Intake VMax Ported TB JRE Tune |
#45 | |
![]() Drives: 2016 2SS M6 Join Date: Feb 2011
#46 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Norm
'19 WRX 6M (the family sedan . . . seriously) |
#47 |
![]() Drives: 2016 SS Hyper Blue Join Date: Jan 2016
Call it whatever you want, but when I hit the gas I want to go...not wait for the car to decide how much throttle it wants to give me. 40k miles and the car still feels too unpredictable. That and the rev hang...when I let off the gas I want to SLOW DOWN.
#48 |
Drives: 2016 Camaro SS Join Date: Oct 2016
As I've said before... GM filters the pedal input in all but track mode. If you want immediate pedal response you need to be in track mode. Sport and touring mode will filter out these transients. Neither EFI Live or HP Tuners expose anything related to the filtering so a tune will not help.
The pedal to torque output relationship can be adjusted via a tune. Tim |
#49 |
![]() Drives: BVM 1SS Join Date: Oct 2016
Rev hang?
#50 |
That's just how I've heard it referred to. In the M6 when you go for an upshift the computer will let it drop to about 2k RPM and hold it for a bit to allow you to shift into the next gear...just another annoying, unneeded throttle interfeernce. My bet is the lack of 'slow down' is related to that
#51 | |
Yes, I suspect it's related, possibly via abrupt increases to high manifold vacuum (low MAP). Norm
#52 | |
#53 | |
#54 | ||
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Dec 2015
#55 | |
#56 |
Ok paid attention going home and now I know what it's doing. W/o rev match it'll still try to hold the revs for the next upshift, but only for like a second or two. I only notice it when skipping gears (i.e. 4th to 6th). Otherwise it doesn't interfere. But it assumes you're not gunna skip a gear
