Old 07-03-2017, 10:43 PM   #43
DenverTaco07
DenverTaco07's Avatar
Originally Posted by 1LEfireman View Post
So I have the same clicking noise but only when I auto X. Did anyone mention that the clicking noise is the Ediff doing its thing? Makes sense to me. I never hear it driving around town. Thoughts???
the ticking noise most refer to eminates from the fron wheels, but you may have another noise.
Old 07-05-2017, 08:04 AM   #44
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
The Ediff makes no noise. Its definitely noise from the front wheels. See my posts about fixing the issue with anti seize on the mating surfaces.
Old 07-28-2017, 09:28 PM   #45
HYPER1LE
HYPER1LE's Avatar
Drives: 2017 Chevrolet Camaro SS 1LE HBM
I'm hearing it too 😐
HYPER1LE is offline   Reply With Quote
Old 07-31-2017, 07:48 AM   #46
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I created a fix thread. I haven't had the noise return since.
http://www.camaro6.com/forums/showth...t=noise+solved
Old 08-19-2017, 05:13 PM   #47
RedDragonSS2.0
RedDragonSS2.0's Avatar
Drives: 2017 Summit White Camaro SS 1LE
Just showed up on my camaro 1500miles, going to attempt to clean it up myself since it's time for a full detail anyways.
Thanks for the info as usual guys...
Rotofab Intake, Borla 60606 Midpipes, Corsa Extreme Axleback
RedDragonSS2.0 is offline   Reply With Quote
Old 08-20-2017, 03:02 PM   #48
high_climber
Drives: 2017 1LE Hyper Blue Metallic
Mine had it at 1200mi...it was just loose lug nuts and I noticed the locking lugs in particular were looser than the rest. A little umph on the lug wrench later and she's quiet
high_climber is offline   Reply With Quote
Old 09-29-2017, 05:10 PM   #49
HYPER1LE
HYPER1LE's Avatar
Update: No more clicking/ticking. Dealer followed service bulletin on this issue. Interestingly, other GM vehicles do this too. I saw one was the Buick Enclave. I don't imagine those are driven quite the same as ours...LOL
Old 09-29-2017, 11:03 PM   #50
Rockmonstir
Rockmonstir's Avatar
Drives: 2017 Camaro SS 1LE
I took my car in before my first trackday and had the dealer do the service bulletin as well. No ticking to report of!
I pick things up then put them back down.
Rockmonstir is offline   Reply With Quote
Old 10-26-2017, 07:05 AM   #51
sheitz630
sheitz630's Avatar
Drives: 2016 2ss Camaro
I am currently having the same issue. I took it to the dealer and they told me I needed a new differential. Confused, I let them (it's under warranty so I didn't have to pay for anything). As I left the dealership I heard the noise. I hear it when driving straight as well as turning; definitely speed dependent. Going to try to tighten the lug nuts today.
sheitz630 is offline   Reply With Quote
Old 10-26-2017, 07:23 AM   #52
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
See post #46
Old 10-27-2017, 04:08 AM   #53
MJP
MJP's Avatar
Drives: 2018 Camaro 1LE Summit White
Finally some benefits from losing your hearing as you go up in age.
Keep on Clicking...
MJP is offline   Reply With Quote
Old 11-05-2017, 06:55 PM   #54
ride98red
ride98red's Avatar
Drives: 2017 Summit White Chevy Camaro 2SS
Just this weekend I started hearing the clicking/ticking from the front wheel area. Almost 4k miles on mine. I've had my wheels off my car several times now for general detailing/cleaning, caliper painting efforts and now at almost 4k miles the clicking/ticking starts???? I always torque the nuts to spec. wonder if those with aftermarket wheels have the ticking/clicking.
ride98red is offline   Reply With Quote
Old 11-05-2017, 08:32 PM   #55
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
I think Clicking is just a thing to live with Two piece rotors, you can minimize it but GT350, GT3 RS, and C7 Z06 at autox I went to this weekend had some level of corner ticking from brakes. Clean the surfaces and I do two stages 75ft/lb then 140ft/lb sometimes it ticks and other times its quiet.
thescreensavers is offline   Reply With Quote
Old 11-06-2017, 09:50 AM   #56
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Has nothing to do with proper torque. I torqued mine properly and still had clicking. Next time you have them off rub a little anti seize on the mating surfaces specifically around the hub. No need to overdo it a little dab will smear most of the surfaces. I made a thread about this fix. Frankly I wish they would sticky it so people could find it easier.
http://www.camaro6.com/forums/showth...licking+solved
This is the common misconception from most who choose to not fix it but I'm telling you its not the rotors. My fix in the thread linked above has lasted now for about 10k miles of daily driving AutoX, track day, and most recently a hard run up the Tail of the Dragon. Still not a bit of clicking has returned. Very simple fix and I have yet to hear anyone try it who said the clicking returned. However the dealer TSB only cleans the hubs and once the surface corrosion returns so does the clicking. My fix prevents the corrosion from returning.
