Old 04-05-2017, 12:55 PM   #43
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Originally Posted by F1FTY View Post
Great point about the memory seat controls
Here's a photo of the passenger seat connector. That would eliminate the pins for memory:
https://flic.kr/p/TzXLUZ
No lumbar adjustments, just front to back, height and seat back angle
Definitely still some major differences. I suppose we won't learn much without a wiring diagram.
Old 04-05-2017, 01:09 PM   #44
F1FTY
Drives: 2018 ZL1
Yup. Wiring diagram and pin out
I'm wondering now if the 1LE seats are the same as the ZL1 except for stitching color and badge. If so, do these seats all plug and play with the 2SS harness?
It might be a case of replacing/splicing the 1SS/1LE harness and adding dash buttons. Maybe they're all connected on the same wiring and it could be an easy job.
F1FTY is offline   Reply With Quote
Old 04-05-2017, 01:19 PM   #45
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I really hope so! I'm hoping someone figures it out soon. I would love to have these features!
Old 04-05-2017, 01:45 PM   #46
WhyUMad1LE
Drives: 17 SS 1LE
Unfortunately it seems the heat/vent seat switches are part of one unit along with the HVAC controls. Then you would have to buy the dual zone ac harness, heat/vent seat harnesses, and dual zone heater control module. Maybe reprogram the HMI too?
Our most economical solution is to fab our own switch.
Old 04-05-2017, 01:47 PM   #47
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Well if it's anything like the doors it is the farthest thing from simple... When I swapped to the ZL1 door panels (basically a 2SS panel with suede instead of leather) I had to completely remove the harness from the new panel and replace it with the one from my stock panel. Basically the 2SS/ZL1 harness did not agree with the 1SS so everything didn't work correctly.
I have a feeling that just adding those dash buttons will be a nightmare, and trying to wire them up will be worse.
IG: @NC_M1SS1LE
Old 04-05-2017, 01:51 PM   #48
F1FTY
Drives: 2018 ZL1
Last two posts make me go yikes. This looks very involved to pull off an OEM solution.
Anyone local want to see if the heating and cooling work with my 2SS?
Old 04-05-2017, 02:16 PM   #49
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
I live in Crofton, MD! Probably not too far from you!
IG: @NC_M1SS1LE
Old 04-05-2017, 02:46 PM   #50
F1FTY
Drives: 2018 ZL1
Vienna, VA here! Katie's Cars and Coffee this weekend?
Old 04-05-2017, 02:52 PM   #51
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Yeah, it looks like adding and getting the OEM dash buttons to function would be a nightmare and cost just more than it's worth...
Now, it a company came up with a plug and play into the seat harness, and (here is the key) a decent looking little module/box thingy with the heat/cool buttons in it that could attach to the seat sides, that would work too. As long as I said, it looked good...meaning a black plastic that matches, OEM quality switches, small in size, etc...that I would buy. But if it looked like a cheap plastic box with Pep Boys toggle switches, I would pass.
Old 04-05-2017, 03:10 PM   #52
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Ohh yea we can figure it out after Katie's! Sounds like a plan!
Sit tight everybody I figure we can take out my passenger seat and hook it up in his car as a proof of concept, if it works then we will know that we are really onto something!
IG: @NC_M1SS1LE
Old 04-05-2017, 04:08 PM   #53
Camaro6717
Drives: 2017 Camaro 1LE
Here it is, I tried to power it under the seat and it didn't do anything goes so I took it out. Going to see if I can get it to work outside the car now.
Camaro6717 is offline   Reply With Quote
Old 04-05-2017, 04:30 PM   #54
Camaro6717
Still doesn't work by just wiring up the black and red. After testing my wife's car, which has ventilated seats, the red and black have full voltage all the time. The blue wire voltage changes with speed. It was something like 3v @ full speed, 5v @ Media and 9v @ low
Old 04-05-2017, 04:51 PM   #55
devnull
Scientific negotiator
devnull's Avatar
Drives: 2019 Grand Sport
That makes sense, it is your 'speed controller'
Would be easy to wire in a voltage drop to vary the speed too...
grab a 5v regulator... STAT! haha (good work!)
2019 Grand Sport M7
2018 ZL1 1LE 6MT
2017 SS 1LE 6MT
Matthew 25:40
ΜΟΛΩΝ ΛΑβΕ
devnull is offline   Reply With Quote
Old 04-05-2017, 04:59 PM   #56
Mr. Meh
Drives: Sold
Reminds me of variable RPM fans in computer cases using PWM controllers -- either auto in BIOS or front mount dials.
Mr. Meh is offline   Reply With Quote
